04-26-2020, 02:52 PM | #1 |
Quarry Creeper Join Date: Jun 2018 Location: CRG
| Axle link mounting points
Can someone get me some quick measurements of the link and shock mounting locations on the Capra axles? I just need the width between left and right rod ends. :beer:
04-26-2020, 03:50 PM | #2 |
RCC Addict Join Date: Dec 2014 Location: So Cal
| Re: Axle link mounting points
Links are 3" wide centerline of the tabs, shocks are 3-7/8" centerline on tabs. Just set my bare Bomber cage on top of an upside doen Capra. At full lock, the tires hit the upper frame rail. With articulation out back, same issue.
04-26-2020, 04:27 PM | #3 |
| Re: Axle link mounting points I guess you probably know where my head is at. Are you saying that the Bomber cage is still too wide for the Capra axles? If the axles were "right-side-up," would there be more (enough) clearance above the 4.75" tires? I'm trying my hardest to bring this project of mine to a finish and it's had a few setbacks. |
Axle link mounting points - Similar Threads | ||||
Shock Mounting Axle vs Link | Yamaguy | General Crawlers | 0 | 12-17-2014 08:35 PM |
Hitec 7980 mounting points | simon170 | Electronics | 7 | 10-12-2012 02:59 PM |
Shock and Link Mounting on Axle..what 1ST | jeepster73 | Axial AX-10 Scorpion | 3 | 10-30-2010 08:26 AM |
AX Link and shock mounting, Vs Berg mounting locations. | BEELZEBOB | Axial AX-10 Scorpion | 4 | 06-09-2009 04:04 PM |
interference help - all metal mounting points... | BlueMonster | Electronics | 4 | 09-29-2006 05:59 PM |
