12-04-2015, 08:16 AM | #1001 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: Axial rr10 |
12-04-2015, 08:17 AM | #1002 |
Newbie Join Date: Dec 2015 Location: waterford
| Re: Axial rr10
New to crawlers and this forum. Always wanted a crawler and seen this at my local hobby shop and just had to have it. Looks like I will learn a lot from you guys and you can help me spend my money. First thing my son said when I got home was "I want one!" So looks like I will have to pick up another one for christmas.
12-04-2015, 08:39 AM | #1003 |
| Re: Axial rr10 |
12-04-2015, 08:53 AM | #1004 |
| Re: Axial rr10 It shows. You don't get the face full of nasty factory air when you open the box. The small things on this keep showing up. The wraith body would always get wrecked along the bottom edge, the rr10 has a slider built in to protect it. There's a nice little gap over the top of the battery box to tuck the wires. Nailed it on this one. I haven't even managed to break it yet |
12-04-2015, 09:08 AM | #1005 |
Rock Stacker Join Date: Sep 2015 Location: Florida
| Re: Axial rr10
My work in progress. |
12-04-2015, 09:23 AM | #1006 |
Pebble Pounder Join Date: Feb 2014 Location: tucson
| Re: Axial rr10
I have those same wheels on mine. They look pretty good.
12-04-2015, 10:17 AM | #1007 |
Newbie Join Date: Nov 2015 Location: Upland
| Re: Axial rr10
JDAY Where'd you find the scale fuel tank
12-04-2015, 10:26 AM | #1008 |
Quarry Creeper Join Date: Oct 2004 Location: Somewhere in the middle
| Re: Axial rr10
That looks like the stock tank that comes with the bomber just painted all pretty like Sent from my SM-T800 using Tapatalk |
12-04-2015, 11:31 AM | #1009 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
| Re: Axial rr10
FYI: RR10 Bomber is back in stock @ Tower....limited quantities.
12-04-2015, 12:04 PM | #1010 |
| Re: Axial rr10 |
12-04-2015, 12:46 PM | #1011 |
| Re: Axial rr10
Advantages/disadvantages of using the front or rear sway bar mount at the rear axle? I would like to remove the lugs all the way at the back, but it looks like most people have the sway mounted there. |
12-04-2015, 12:52 PM | #1012 |
| Re: Axial rr10
RPP shows ProLine's 5 inch shock is finally coming out. That'll give us another option for rear shocks as well with the rear upper shock mounts.
12-04-2015, 01:42 PM | #1013 |
| Re: Axial rr10
If anybody noticed in my picture above, I have the vanquish trailing arms. I put the lower shock mount in the middle hole and the top shock mount in the rear hole which really seemed to stiffen up the rearend and reduce the torque twist. There is still some torque twist but not near as bad. |
12-04-2015, 01:48 PM | #1014 |
| Re: Axial rr10
Finally, mine is in hand....maybe the first one in Canada? Let the build begin....
12-04-2015, 04:15 PM | #1015 | |
Pebble Pounder Join Date: Jan 2014 Location: San Jose
| Re: Axial rr10 Quote:
Sent from my SM-G900P using Tapatalk | |
12-04-2015, 04:34 PM | #1016 |
| Re: Axial rr10
Upper and lower arms in the back are Yeti. I have the VP yeti trailing arms on mine, also using the rear front upper mount and center lower mount.
12-04-2015, 05:17 PM | #1017 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
| Re: Axial rr10
Was in my LHS today, they had two Bombers sitting on the shelf...
12-04-2015, 06:25 PM | #1018 |
Pebble Pounder Join Date: Aug 2013 Location: near jax
| Re: Axial rr10
Added extra shocks to all 4 corners. It can hit a shallow curb go air born flat and land perfectly on all four and keep hauling at 20+ mph. I have a hobbywing 3656sd 4000kv with 15t pinion with a mmp. Ordering my sway bar next week to reduce twist. |
12-04-2015, 10:25 PM | #1019 |
Pebble Pounder Join Date: Nov 2014 Location: philadelphia
| Re: Axial rr10
Ordered mine Wednesday and tower said it should ship Monday. Interesting to hear a lot of people wanting to get the sway bar to tame the torque twist. I wanted the same with my yeti XL but after a year with it turns out I love that toque twist and ended up detaching the sway bar.
12-05-2015, 01:43 AM | #1020 |
| Re: Axial rr10
I was all worried using SSD's centered rear diamond axle for nothing....I have absolutely zero clearance issues with the MIP Yeti driveshaft. Whew!
Axial rr10 - Similar Threads | ||||
fun day at the (axial wraith rock race - scalers axial honcho - axial discovery) | gionata78 | Scale Videos! | 1 | 08-06-2013 11:52 AM |
