12-05-2015, 03:04 AM | #1021 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
| Re: Axial rr10 |
12-05-2015, 08:16 AM | #1022 | |
RCC Addict Join Date: Jan 2007 Location: Arkansas
| Re: Axial rr10 Quote:
Also all my shocks were pretty much dry out of the box so I put some 30wt in them. | |
12-05-2015, 08:53 AM | #1023 |
Pebble Pounder Join Date: Feb 2014 Location: tucson
| Re: Axial rr10 I think I'm going to wait on were I want to mount my sway bar. To put the bar in the back were they are, they have to open up that hole. I'm a little worried it might make the wall thickness a little thin. So I want to see how it holds up to some abuse for a while.
12-05-2015, 09:13 AM | #1024 |
Pebble Pounder Join Date: Aug 2013 Location: near jax
| Re: Axial rr10
working on camera placement for my fpv setup. https://youtu.be/-nLVwPB9O7s |
12-05-2015, 09:26 AM | #1025 |
| Re: Axial rr10 |
12-05-2015, 09:32 AM | #1026 |
Rock Crawler Join Date: Oct 2006 Location: New Tripoli, PA
| Re: Axial rr10
I said I was going to wait to see what the kit entailed, but my willpower is waning Cheers, Wade |
12-05-2015, 10:09 AM | #1027 |
| Re: Axial rr10
It's either happier now and later or just happier later.
12-05-2015, 01:26 PM | #1028 | |
RCC Addict Join Date: Aug 2013 Location: Missoula
I have mine build toward the Yeti end of the spectrum. Faster and lower than optimal for crawling. The low belly height will help with traction rolling significantly. Looking in to the sway bar mounts a little more, it seems the rear mounts are from the Wraith. The front mount are more like the Yeti. I'm going to try the front mount, hoping I can cut the rear ones off. Found a pic on the home page here | |
12-05-2015, 01:48 PM | #1029 | |
Quarry Creeper Join Date: Dec 2011 Location: spokane
12-05-2015, 02:22 PM | #1030 |
| Re: Axial rr10 |
12-05-2015, 02:31 PM | #1031 |
Quarry Creeper Join Date: Oct 2011 Location: liberty
| Re: Axial rr10
I have mine all put back togethernow. I put the VP Chubs, knuckles, lockouts and brass front wheel weights from my XR 10. Removed the drivers and painted drivers,helmets and addedsome scale stuff. I really like the tires but the wheels did not work withe the weights. I am now removing tires from the glue on Axial wheels. Gonna get them on an extra set of VP wheels.
12-05-2015, 03:21 PM | #1032 |
| Re: Axial rr10 Must be Brandon's rig. He is the only one I know that has done it nicely. He said the s30 were made to be glued on and the r35 will be more friendly to internal beadlocks just incase anyone else was having and issue.
12-05-2015, 05:20 PM | #1033 | |
12-05-2015, 08:24 PM | #1034 |
| Re: Axial rr10 |
12-05-2015, 09:28 PM | #1035 |
Rock Stacker Join Date: Dec 2004 Location: Parker, CO
| Re: Axial rr10 |
12-05-2015, 09:43 PM | #1036 |
Rock Crawler Join Date: May 2007 Location: Salt Lake City
| Re: Axial rr10 From my measurements axial trophy truck score shocks will fit perfectly on the rr10 front and rear and will match the existing shocks.
12-05-2015, 09:49 PM | #1037 |
| Re: Axial rr10 |
12-05-2015, 10:52 PM | #1038 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
| Re: Axial rr10 |
12-05-2015, 11:48 PM | #1039 |
Pebble Pounder Join Date: Nov 2014 Location: philadelphia
| Re: Axial rr10
I'm curious why the Holmes trailmaster pro is the choice in many builds when it is only a 2 pole motor. Why not use a 4 pole motor to get the low end torque requirements covered better? Wouldn't you want a holmes pullerpro over the trailmaster pro here or any 4 pole motor over 2 pole motor in general?
12-06-2015, 12:01 AM | #1040 |
| Re: Axial rr10
Technically, you are spot on with your reasoning relay1....but with that being said, I have been running this motor in my Wroncho Bug for quite a while and it crawls incredibly well, especially with low speed technical maneuvers. I will eventually get a new Puller Pro to try them out though. Folks say they are just as good, if not better than the ROC412 series and I have a few of those and they are great motors.
Axial rr10 - Similar Threads | ||||
fun day at the (axial wraith rock race - scalers axial honcho - axial discovery) | gionata78 | Scale Videos! | 1 | 08-06-2013 11:52 AM |
