Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: Bomber Batteries
Old 12-22-2015, 11:45 AM   #21
Default Re: Bomber Batteries
two small 2mm hex screws when you look down inside on the bottom edges you can see them
it moves the cage front to back a bit but does not make it go down deeper which for me is more the issue the height as the battery sits in from bottom to top is the same sadly
at least I did not see it change from top to bottom
the amount it misses by is small for me and I noticed the little cage thing that flips down has some raised edges I might just cut those down and see if that makes it easier which I think it will
my other idea was aluminum hood then take out that plastic thing that flips down and replace it with a small piece of CCF on the hood to keep the battery in there better
Originally Posted by relay1 View Post
How do you adjust the battery tray?
Honu is offline   Reply With Quote
Old 12-22-2015, 10:52 PM   #22
Originally Posted by derycksan View Post
Running SMC 3200 4s 60c. Little tight width wise but they just fit.
running stock ESC?
1beatjeep is offline   Reply With Quote
Old 12-23-2015, 12:46 AM   #23
Originally Posted by 1beatjeep View Post
running stock ESC?
Mmp, had to turn it sideways to fit but it all gets in there.
Sent from my SM-G900P using Tapatalk
derycksan is offline   Reply With Quote
Old 12-24-2015, 11:02 AM   #24
Like a glove. Haven't had a chance to run them, or solder on my connectors either. Will report back again once I get a few cycles on them.
terrible is offline   Reply With Quote
Old 12-24-2015, 11:39 AM   #25
That's as big as my 5200 and 5000 mAh batteries... Figured it was a 4s. Wonder why they're so large for 3600mAh?
maslin is offline   Reply With Quote
Old 12-24-2015, 01:22 PM   #26
This humped battery fits quite snug...
jediwebdude is offline   Reply With Quote
Old 12-24-2015, 01:41 PM   #27
Cause it's cheap ? I dunno, my 5000 3s was wedged in there and I didn't like not having anything on the outside of the pack (no shrink wrap or anything). And my 4k packs fit my yeti perfectly so I didn't want to cut them up.
Old 12-24-2015, 10:24 PM   #28
Do you have a link or brand for the packs your running?
Stuck is offline   Reply With Quote
Old 12-28-2015, 09:15 AM   #29
Venom 3s 5000mAh
http://www.amazon.com/Venom-5000mAh-.../dp/B0042JD6S8
I would have sworn the other is a 5200mAh Traxxas, but I can't find any online. It's tucked away in my lipo box, I'll check it out tonight.
Edit: it's a Rage 3s 30c 5200mAh. Just barely fits in there, the Venom fits just right. I also shaved down the circles to get the pins in easier.
Amazon.com: Rage RC LP52003S30T 5200mAh 11.1V 3 Cell Lipo Sport Battery Pack, T Plug: Toys & Games
Old 12-28-2015, 12:47 PM   #30
the little thing that folds down to hold the battery in better I just decided to trim off the top circle parts a touch maybe 2mm off the top and is very easy to put the pins in now and no play with it
you can see the circle parts well in jediwebdude last pic he posted
Old 12-28-2015, 01:24 PM   #31
i bought the duratrax 5000 with my bomber from Tower and it was a tight fit but all i did was put the pins in from the inside instead of the outside and had no issues closing and pinning the hood. it fits nice and snug but i think i am going to order some 4s batteries and see how those work. in hindsight i would have waited and bought batteries after my bomber arrived. well, you live and learn. anyone need a 3s 5000mah lipo?
Delbert is offline   Reply With Quote
Old 12-28-2015, 01:54 PM   #32
Lectron pro 5200mah 50c 3s soft pack fits perfect.
Dimensions from there site is 133x42x27mm.
84yoda is offline   Reply With Quote
Old 12-28-2015, 07:42 PM   #33
I'm running the same battery as Maslin and I would recommend it and Venom batteries in general. The one problem I did have with one of their batteries was made good when they sent me an upgraded replacement with no questions asked. I like when a company stands behind their products like that.
SCREAMER is offline   Reply With Quote
Old 01-19-2016, 09:19 AM   #34
Thumbs up Re: Bomber Batteries
This is the largest size that Bomber Fabrication recommends.
Battery for Axial Bomber – Bomber Fabrication
I talked to them, and they say this is the biggest dimensions they recommend, and do not recommend shoving anything thicker or taller into the battery tray. I haven't purchased one yet, but probally will soon..or fine one the same dimensions.
DuraTrax LiPo Onyx 3S 11.1V 5000mAh 25C Soft Case Battery with Deans Plug P/N: DTXC1867
Voltage Rating: 11.1V
Rated Capacity: 5000mAh
Watt Hours: 56Wh
Weight: 13.5oz (383g)
Balancing Connector: ElectriFly
Discharge Rating: 25C continuous
Dimensions: 1.7 x 1.2 x 5.4" (43 x 31 x 137mm)
Discharge Lead/Connectors: 12AWG Wires, Deans Plug
MD ENFORCER is offline   Reply With Quote
Old 01-28-2016, 06:51 PM   #35
I bought this battery:
https://www.rpphobby.com/ProductDeta...tCode=DTXC1967
Dimensions: 1.7 x 1.2 x 5.2" (43 x 30 x 133mm)
Lengthwise it fits but it's tight - but it's too tall, the hood won't close at all. Way too big. Can't see how the above battery could fit.
lotsalemon is offline   Reply With Quote
Old 01-28-2016, 07:26 PM   #36
I am using this same battery. While it is only 3600MAh I ran one of mine for 100 minutes weekend before last when I was out with our group. And much of that was n pretty hard running, several others were swapping in fresh batteries and mine was still going strong. When I charged it I put in 2800MAh and it was only down to 11.54v. I am happy with them!
USP45 is offline   Reply With Quote
Old 01-28-2016, 09:43 PM   #37
http://spcracingbatteries.com/index....&product_id=96
I'm running this one. Drops in nice, and a little bit of a pain to get my fingers in to get it out, so....perfect! Not to tall, so the hood shuts nice.
xmikedentx is offline   Reply With Quote
Old 01-29-2016, 06:28 AM   #38
Originally Posted by xmikedentx View Post
SPC LiPo Power, Lithium Polymer (LiPo) Battery Pack; 6500mAh, 65C, 2S, 7.4V Hard-Case, Deans
Yours is...
Weight: 13.4oz (380g)
http://spcracingbatteries.com/index.php?route=product/product&path=59&product_id=96
PACK DIMENSIONS: 138.5mm long x 46.5mm wide x 25mm tall. 395g.
Also, I was just going off the information I was given by Bomber Fabrications.
Mike did you adjust the battery tray any?
Old 01-29-2016, 08:19 AM   #39
Nope, slides right in!
Old 01-29-2016, 02:11 PM   #40
My battery must be 43 mm tall, 30 mm wide. I'll double check when I get home.
The measurements as they were listed on RPP didn't designate L or W.
Bomber Batteries - Similar Threads
Tedo's Bomber tedo Axial RR10 Bomber 3 02-08-2016 07:47 AM
Bomber axel Mitchell72 Axial RR10 Bomber 2 12-12-2015 09:18 PM
Hawaii Bomber BakedMopar Videos! 0 12-12-2015 07:35 PM
Backwoods Bomber Duuuuuuuude 1.9 Scale Rigs 153 06-11-2012 08:41 AM
