12-15-2015, 03:06 PM | #1 |
Newbie Join Date: Nov 2015 Location: Okinawa, Japan
| Smitty's Build
Will continue to update this first post as I change my setup... Front Axle/Susp/Steering: VP OCP V2 Housing (Wraith) VP Locker VP VVD V1 HD VP Diff Cover VP Truss VP Link Mounts VP Chubs (non-clamping from stage 1 kit) VP Knuckles (non-clamping from stage 1 kit) Axial Servo Plate (56mmx17mm) VP Servo Mounts (Wraith) Savox 1270 Monster Torque HV servo Pro-line Pro-spec SC Rear Shocks (100mm) Axial HD Bevel Gear (38/13) VP Wraith upper/lower Ti links VP SLW 350 Hub Rear Axle/Susp: VP OCP V2 Housing (Wraith) VP Locker VP Diff Cover VP Truss VP Link Mounts VP Lockouts (non-clamping type from stage 1 kit) Pro-line Pro-spec SC Rear Shocks (100mm) Axial HD Underdrive Bevel Gear (43/13) VP Yeti Trailing Arms VP Yeti upper Ti links VP Yeti Currie Sway Bar VP SLW 725 Hub Wheels/Tires: VP Method 2.2 Beadlock Race Wheels Pit Bull 2.2 Rock Beast II Tires CI Deuce's Wild Single Stage 2.2 Foam (tall) VP SLW 350 hubs (front/rear) Driveline/Power System: MIP Yeti X-Duty Rear C-drive kit Holmes Hobbies Puller Pro 540 XL 13T pinion/Axial Stock 64t spur STRC Motor Mount Mamba Monster X ESC CC BEC Still shopping for... -Front drive shaft (not sure what fits) -Bearing kit Last edited by smittycm; 12-30-2015 at 04:39 AM. |
12-25-2015, 12:33 AM | #2 |
| Re: Smitty's Build |
12-25-2015, 12:39 AM | #3 |
| Re: Smitty's Build
You may want to make sure you put the 43/13 underdrive gears in the rear and not vise versa.
12-25-2015, 12:41 AM | #4 |
| Re: Smitty's Build
Was bashing around in a rocky ditch behind my house and lost steering. Thought I busted my servo gears, but couldn't believe I would bust titanium gears just bashing around like I was. Turned out to be the servo arm. Cleaned the stripped aluminum shavings off my servo, and the gear looks good as new. Not chewed up at all. Can't say the same for the aluminum arm though. Really loving the Savox 1270TG servo I'm running. It's fast (almost too fast), and has monster torque (~480 oz-in). Running my BEC at 7v, so not maxing the servo out or anything. This thing did a job on my servo arm. You can see the weak point in the pic below. Going to try a single clamping arm next and avoid the double-clamping type arms in the future. |
12-25-2015, 12:44 AM | #5 |
12-25-2015, 09:21 AM | #6 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Smitty's Build
Try the axial aluminum double clamp servo horn, you won't have any problems.
12-25-2015, 11:42 AM | #7 |
Newbie Join Date: Apr 2013 Location: San Antonio
12-25-2015, 11:52 AM | #8 |
| Re: Smitty's Build
Turn sharper, less torque twist, better climbing.
12-27-2015, 06:15 AM | #9 |
| Re: Smitty's Build
Picked up servo arm (non-clamping style) to tide me over until I get my next shipment of parts. Also replaced the interior with a piece of smoked plexiglass same as I used on the body panels. Waiting on a few things to show up in the mail... - Puller Pro XL 3500kv - Castle X Series Sensor Harness (so I can run my Monster X ESC with the Puller Pro XL) - Clamping type servo arms - Couple more pinions - Few other odds and ends, and parts for the Slash Sucks waiting on shipping to Japan for everything, but not as bad as some of the unlucky folks in other countries. At least I can still use USPS through the military postal system. Really digging the blacked out look... |
12-29-2015, 01:07 AM | #10 |
| Re: Smitty's Build
Got the Puller Pro XL 3500kv in today. Here it is side by side with the Pro4 HD 3000kv I've been running. Hard to tell from the pic, but the Puller Pro XL is just a couple millimeters longer. Moved the 13T pinion over from the Pro4 HD. All things being equal, the Puller Pro XL has got more punch to it, and is noticeably faster. That extra 500kv is really noticeable on 3s. Runs nice and cool too. It's a little less smooth on the low end compared to the Pro4 HD, but just barely. No surprise there though. Holmes Hobbies clearly states they gave up a little on the low end with the XL. I do more bashing around the yard than I do crawling, so I'm fine with it. Is still plenty easy to be smooth on the rocks with the expo I have dialed in. LOVING THIS MOTOR! |
12-30-2015, 12:59 AM | #11 |
| Re: Smitty's Build
The Sensor Harness for my MMX finally showed up today. Tore the Bomber apart again today to wire up 6.5mm leads to the Holmes motor, and programmed the MMX to include putting drag brake on 3rd channel. VERY NICE to be able to turn drag brake on/off with the flick of my thumb! I can go bombing through the grass chasing the kids around, and then quickly turn the drag brake on when I hit the little ditch behind my house and start climbing over some rocks. Been working on dialing in the handling as well... - Changed the fluid in my shocks to 400 CST up front and 600 CST in the rear. Made a huge difference over the 200/front 300/rear I was running. Was way too bouncy before. - Put SLW 725 Hubs on the rear to widen the rear stance. - Dialed in a little more negative expo on the steering. Set it to be pretty linear until right at the very end, then goes to full lock. Easier to steer at speed while still having full turning radius available when crawling. All of these little tweaks have really made a huge difference in the handling. I have a set of springs for the Pro-Spec shocks on order so I can try to dial the suspension in a little more, but it is night/day improvement over stock. This thing is coming along nicely. Really falling in love with this vehicle! Last edited by smittycm; 12-30-2015 at 04:38 AM. |
01-09-2016, 06:07 PM | #12 |
| Re: Smitty's Build
Just found out the CF panels have shipped. Can't wait to get my hands on them! Chopped up some 1mm aluminum to create some panels of my own until the CF panels get here. Also fixed the interior up a little and did a little painting here and there. Ordered the RR Gen 3 Slipper setup. Waiting to see what SuperShafty does with the transmission, and still need to find me a good front drive shaft option, and then this thing will be just about bullet proof! |
01-09-2016, 07:50 PM | #13 |
Rock Crawler Join Date: Dec 2015 Location: Charlotte, NC
| Re: Smitty's Build
Any videos?
01-09-2016, 08:36 PM | #14 |
| Re: Smitty's Build
Sorry, no. Usually just me bashing around. Gonna have to teach one of the kids how to record, or figure out how to mount my gopro.
01-09-2016, 09:53 PM | #15 |
| Re: Smitty's Build
Did you cut down the brass bushings for the currie sway bar?
01-10-2016, 03:30 AM | #16 |
| Re: Smitty's Build No. I carefully drilled out the hole in the chassis about half way through in order to countersink the brass bushings a little bit. Didn't take much. Didn't want to cut the bushings because I planned to eventually mount the sway bar back in the stock location once I had a chance to make some shorter links, but once I got it mounted I decided I actually like the sway where it is. The link lengths are fine in that location. Bar is about level, and I get just about full range of motion with only minor interference at about 1/8" before full stuff. |
01-10-2016, 04:58 AM | #17 | |
| Re: Smitty's Build Quote:
01-10-2016, 03:17 PM | #18 |
| Re: Smitty's Build Haven't played with different settings yet. About to leave TAD for a couple weeks, so it will be a little while before I get a chance to really play with the settings and test it out.
01-26-2016, 05:01 AM | #19 |
Smitty's Build - Similar Threads | ||||
scx10 G6 2.2 Wroncho/Wrangler Build (AKA The Sleeping On The Couch Build) | Irishchamp | 2.2 Scale Rigs | 45 | 10-09-2014 10:26 PM |
Jeep scaler build and comp micro crawler build | droopmodmrc | Losi Micro-Rock Crawler | 1 | 12-25-2012 12:34 PM |
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ | 53 willys | General Crawlers | 108 | 11-28-2011 12:42 AM |
Smitty's C3 FJ Tuber!!! LA GRASA DIABLO | 253Smitty | 2.2 Scale Rigs | 4 | 01-19-2011 01:06 PM |
RcBros LCC Build, Hi-Res pics & More Build!! | RcBro | Team Losi Comp Crawler | 30 | 06-03-2009 07:26 PM |
