12-17-2015, 04:02 PM | #1 |
Pebble Pounder Join Date: Feb 2014 Location: tucson
| extra shock or sway bar or both
Here's a question for ya. Do you think you still need a sway bar if you run dual shocks in the rear? What would the pro's and con's be to one or the other or both?
12-17-2015, 04:03 PM | #2 |
| Re: extra shock or sway bar or both
dual shocks on all 4 and front qand rear sway bars. I like scale. ;)
12-17-2015, 04:14 PM | #3 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
Lol that or single shock f/r with rear sway...
12-17-2015, 05:33 PM | #4 |
Rock Crawler Join Date: Jan 2005 Location: The Hills
dual shocks aren't meant to replace a rear (or front) anti sway bar.
12-18-2015, 05:40 PM | #5 |
The rear has so much travel that no matter how much damping you add, your still going to want the roll stiffness added by the sway bar if you plan on doing anything resembling "handling" at higher speeds. I don't have my Bomber in my hands yet, but I suspect the rear is so floppy that even as a crawler the sway bar will be beneficial. The added damping provided by the second shocks helps with jumping an such. No need for them if just crawling. Advantages to dual shocks would include more precisely adjustable damping, since you now have more options at each corner for oil/pistions, and more total oil capacity (the stockers leak, so more oil means longer running before damping is lousy), plus the bling factor. Downsides would include cost, added weight, added maintenance time, and likely a bit of a learning curve to get setup. These are generalities. Meaning you can thicken the oil (or go to pistons with smaller/few holes) in your single shocks to achieve similar damping as lighter oil in dual shocks. Changing spring rates also changes roll stiffness, meaning stiffer springs will require a softer bar to maintain the same roll stiffness. |
extra shock or sway bar or both - Similar Threads | ||||
sway bar?? | carcueza | Axial AX-10 Scorpion | 0 | 12-15-2015 01:02 AM |
sway bar is done | bill c | Axial Yeti XL | 62 | 03-27-2015 01:02 PM |
HR sway bar | Quartermaster | Axial Wraith | 2 | 12-10-2011 06:49 PM |
sway bar | muddeprived | General Crawlers | 9 | 09-12-2007 09:57 AM |
