11-07-2014, 10:38 PM | #1 |
Quarry Creeper Join Date: Sep 2006 Location: nor cal
| sway bar is done
so I made a sway bar. its adjustable. works as it should, front wheel pull up for 2' then lays down, tire only comes off the ground bout 2'' the car stays straight. I can adjust it about 2'' from the rear of the bar to the front. so softer set up to stiffer set up... I can also adjust the rods shorter or longer, if needed..
11-08-2014, 11:26 AM | #2 |
Pebble Pounder Join Date: Jan 2013 Location: Fall River
| Re: sway bar is done
you should give a parts list so we know what you used to duplicate it. Should have mine this coming friday and thats one of the things ill be figuring out. Thanks and good job Bill
11-08-2014, 08:33 PM | #3 |
parts list....1/8'' music wire (3.18mm) 4 Traxxas rod ends 2 ball ends with set screw. about 3 bucks in parts,, one hour in labor includes 3 beers and bs time with friends Last edited by bill c; 11-08-2014 at 08:36 PM. |
11-09-2014, 11:34 PM | #4 |
Newbie Join Date: Oct 2014 Location: Earth
Looks good man!
11-11-2014, 10:30 AM | #5 |
Newbie Join Date: Nov 2012 Location: Kentwood
This is a pretty good idea. Simple too. Seems like a necessity if you are going to run 6s.
11-29-2014, 05:15 PM | #6 |
Pebble Pounder Join Date: Feb 2009 Location: wilkeson
Are the ball ends with the set screws a traxxas part?
11-29-2014, 09:39 PM | #7 |
I have no clue. found some on e-bay that would fit the size wire we were using. (or as close as we could) came in a kit for about 2 bucks.. bent up the music wire, (home depot) installed work like a champ.. hope this helps..
12-02-2014, 12:57 PM | #8 |
Newbie Join Date: Dec 2011 Location: THE OZARKS
I like this - simple and cheap !
12-02-2014, 08:42 PM | #9 |
| Re: sway bar is done |
12-02-2014, 10:15 PM | #10 |
I'll take one!!!
12-03-2014, 05:53 PM | #11 |
12-04-2014, 04:37 AM | #12 |
Newbie Join Date: Sep 2014 Location: Australia
I can confirm that this method works great. I made a similar one before seeing this thread but I did not bother moving the shocks back. Things improved even more when I made a front sway bar too. Just as cheap using thinner music/piano wire and spare parts I had laying around. The front is a bit trickier though because there is not much room up there but rollovers are dramatically reduced. |
12-04-2014, 07:02 PM | #13 |
12-06-2014, 06:54 AM | #14 |
Rock Stacker Join Date: Mar 2011 Location: Canada, Quebec, Montreal
I went to my lhs for parts for a rear sway bar but the guy couldnt find anything good. I would like to know wich traxxas rod ends are those ? The balls with set screws ? And how did you joint the two rod ends together ? Total lenght ? And how does the piano wire is attached to the chassis ? Sorry for so many questions but i need help ! Thanks |
12-07-2014, 02:40 PM | #15 |
Pebble Pounder Join Date: Nov 2014 Location: philadelphia
| Re: sway bar is done Ok, so here's what I put together so far. Haven't tested anything yet still have some adjustments to make. The music wire is pushed through a section of the chassis I drilled through. I'm ordering threaded collars one for each side of the chassis connection to keep it tight (since I replaced the screws with music wire). I'm also ordering longer standoffs to heighten the sway bar rod connections. Links to the parts I used below. Traxxas ball rod ends Mcmaster-carr threaded standoffs Mcmaster-carr cup point screws (to connect rod ends to standoffs) K&S 2.5mm music wire Last edited by relay1; 12-08-2014 at 09:59 PM. |
12-07-2014, 03:10 PM | #16 |
looks good. why didn't you use the stock mount for the sway bar?
12-07-2014, 03:21 PM | #17 |
12-07-2014, 03:25 PM | #18 |
Rock Stacker Join Date: Jan 2014 Location: Maryborough Australia
Cool, have you got any video of the XL running with the sway bar set up? How do you guy's think a 5ive-t sway bar would go?
12-08-2014, 07:19 AM | #19 | |
| Re: sway bar is done Quote:
12-08-2014, 03:10 PM | #20 |
Pebble Pounder Join Date: May 2009 Location: Sugar Land
Roughly measure the rear bar on the Losi is about 9 -9.5 inches and the front a little over 6". Looks like you need about 7" for the yeti xl, right?
sway bar is done - Similar Threads | ||||
Yeti Sway Bar | deerco | Axial Yeti | 2 | 10-28-2014 06:20 PM |
Sway bar set up | sally1800 | Axial Yeti | 20 | 10-13-2014 01:55 PM |
HR sway bar | Quartermaster | Axial Wraith | 2 | 12-10-2011 06:49 PM |
sway bar | muddeprived | General Crawlers | 9 | 09-12-2007 09:57 AM |
