12-20-2015, 05:42 PM | #1 |
Newbie Join Date: Dec 2015 Location: chattanooga
| For the money. 4 POLE SENSORED VS HAND WOUND BRUSHED
I'm looking to gradually upgrade the bomber for trail /woods running, back yard speed amd occasional crawling. To get that kind of versatility and stay brushed I would think I need a 2speed tranny to keep from heating the motor, a servo to shift it, a quality brushed motor and 3s lipo. ( currently running 2s),. The other option I see is to go 4 pole sensored. If I go the brushless route, do I need to upgrade every drive train component to make it work? Or is there an intermediate level of brushless that is cost effective on 2s and doesn't make me rebuild the entire steering , suspension and drive train? |
12-20-2015, 06:20 PM | #2 |
Quarry Creeper Join Date: Oct 2010 Location: Pa
| Re: For the money. 4 POLE SENSORED VS HAND WOUND BRUSHED
Brushless wouldn't affect the steering, castle link can tone the 3s down somewhat. It's inevitable in the long run, run it til it breaks.
12-20-2015, 06:20 PM | #3 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Brushless for sure. Steering and links should be upgraded either way but everything else should be fine. Maybe later on gears and lockers but for now they will last.
12-20-2015, 06:55 PM | #4 |
So if I'm going brushless, then what is a reasonable mid range combo to use with 2s or 3s that I can put in now? Are there other upgrades that are essential before trying it. Or is it OK to just run it fairly lightlyand fix things as they break? I don't mind to spend a couple hundred on the initial. Where would you put your money if you had 200-300 to spend in making a versatile and solid rig if I'm going the brushless route? |
12-20-2015, 07:06 PM | #5 |
In other words, spend 250 for me on my stock rig to make it brushless and reliable. I already have a 2s lipo.
12-20-2015, 07:51 PM | #6 |
RCC Addict Join Date: Aug 2013 Location: Missoula
MMP, Holmes motor of your choice and a castle BEC. Servo and steering are terrible. The plastic links will need replacement. Pot metal diff gears and lockers will fail. Dog bones in the front are pretty bad too, definitely need an upgrade there. Shocks if they don't work for you, wheels tires and foams are almost required as well. There's a lot of ways to go, a quality brushless setup is pretty high on the priority list. |
12-20-2015, 07:51 PM | #7 |
Pebble Pounder Join Date: Nov 2009 Location: Waterford , PA.
Castle Mamba Max Pro esc and Holmes Hobbies brushless motor of your choice. I would go with the puller pro xl 3500kv.
12-20-2015, 10:32 PM | #8 |
Rock Stacker Join Date: Mar 2012 Location: Truckee
| Re: For the money. 4 POLE SENSORED VS HAND WOUND BRUSHED |
For the money. 4 POLE SENSORED VS HAND WOUND BRUSHED - Similar Threads | ||||
Hand wound versus machine wound motors? | Mysterious | Electronics | 12 | 02-09-2013 12:10 AM |
Ultra cheap, mid level machine wound, or nicer hand wound, worth it? | mdchris | Axial XR10 | 7 | 12-02-2011 07:39 PM |
Hand wound brushed motor? how long should they last?? | 53 willys | Electronics | 0 | 07-08-2009 04:14 PM |
brushless?brushed?hand wound? | buddha.licious | Newbie General | 4 | 02-25-2009 06:52 AM |
