12-24-2015, 02:02 PM | #1 |
Rock Crawler Join Date: Jan 2005 Location: The Hills
| SSD wheels and VP hubs, what combo stops rub?
I've decided to keep my SSD assassassin (HA!) wheels on my bomber but with the stock hubs I'm getting contact on the rear cage and on the battery compartment right behind the faux shock resit on the front. I am using 2.2 pitbull Rb II right now. What VP hub would I need to use to have enough clearance to stop the contact? Seems like .475 would be the one but they are out of stock everywhere but VP direct (no discount) and I hate to buy something just to find out I needed the next size up. Thanks!!! |
12-24-2015, 05:08 PM | #2 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
| Re: SSD wheels and VP hubs, what combo stops rub?
You coukd always go with spacers by gearhead or Dlux fab to achieve wider stance without spending $30 on vp hubs
12-24-2015, 05:11 PM | #3 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
What size hubs are you using now and how bad is the rubbing?
12-24-2015, 07:26 PM | #4 |
Stock hubs that came with the ssd wheels. The rubbing is so bad it stops the wheels in the front and after about 20 minutes of run time it's already polished the screws on the back of the cage from tire contact. I don't want to use spacers. Would rather have the right hubs. |
12-24-2015, 07:40 PM | #5 |
Well Im not sure if they use the same size hubs but the ones that came with my SSD 2.2 and 1.9 steelies were pretty slim. Probably close to a VP 225. I believe each increment is 1/16" but dont quote me. I use 350 SLWs all around on my wraith; not that that helps much... |
12-25-2015, 07:43 AM | #6 |
I couldn't find any fitting info on the slw hubs. I could swear I've seen a chart with each size off set. All I have here is a 225 and 775 from a yeti.
12-25-2015, 09:03 AM | #7 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Try the .725 off your yeti to get an idea. A .600 is exactly .600", each size is 1/8th up or down.
12-26-2015, 06:14 AM | #8 |
I'm thinking its the flex from the links causing the rub on the chassis. The front only touches the frame if I shove enough to bend the lower links. Took a couple pics just for reference. One side is the stock SSD hub (about a VP 225 I think) and other id a yeti size VP 725. Stock: 725 VP hub: Going to try some 350 hubs (if I can find them) and some gear head spacers for now. Looks like new links in the future too....it never ends |
12-26-2015, 08:23 AM | #9 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
I would go with some nice links first. Those craplastic are just that. |
12-26-2015, 04:53 PM | #10 |
But the links make nice impact absorbers ;)
01-13-2016, 07:19 PM | #11 |
Newbie Join Date: Aug 2014 Location: Spokane
Which hubs did you end up going with? I'm looking to run the same wheel/tire combo. Which foams are you running?
01-14-2016, 01:04 AM | #12 |
Pebble Pounder Join Date: Jan 2016 Location: Worthing, England
Great info, I just ordered some 725's for my Bomber, with Irok 2.2's and SSD Steel Beadlocks. Don't know if 725's are going to be too wide, but it'll make it more stable and hopefully rub less. Now thinking I should have got 600's
01-14-2016, 03:56 AM | #13 |
I ordered some 600 hubs and they should be here today. Really wanted 450 but not in stock anywhere for a decent price. I think the 725 on the back of my yeti is what's causing a lot of my axle shaft issues (bending and breaking) . So I didn't want to go too wide on the bomber. I'll snap some pics and post after I get these bolted up. |
01-15-2016, 06:11 PM | #14 |
| Re: SSD wheels and VP hubs, what combo stops rub? |
01-17-2016, 05:40 AM | #15 |
I am amazed at how much less the truck flops now. Did some running on a quick track in the woods and the bomber can side hill quite well now. Does seem to catch the diffs and skid a little more but nothing some throttle can't fix |
SSD wheels and VP hubs, what combo stops rub? - Similar Threads | ||||
Race line Monster Wheels or SSD-RC Assassin wheels | rckjeep | Tires and Wheels | 9 | 07-24-2016 06:30 PM |
More New SSD 1.9 Steel Wheels | SSD | Tires and Wheels | 24 | 12-10-2015 07:33 AM |
axle stops/bump stops limit axle upward movement | meanbgreen | General Scale Talk | 7 | 01-27-2012 03:02 PM |
vanq SLW .100's w/.225 hubs rub on vanq front knickles? | T3rry | Axial XR10 | 6 | 03-16-2011 06:48 PM |
