01-16-2016, 10:32 AM | #1 |
Newbie Join Date: Jan 2016 Location: Leominster
| Battery Fit
Hi All, Don't have my Bomber yet, so I would like to find out something. Would this size battery fit in the Bomber okay. : 138mm long x 46.5mm wide x 36mm tall SPC LiPo Power, Lithium Polymer (LiPo) Battery Pack; 5000mAh, 50C, 3S, 11.1V Hard-Case, Traxxas Thank You, Peter Last edited by SteaminPete; 01-16-2016 at 10:36 AM. |
01-16-2016, 11:15 AM | #2 | |
| Re: Battery Fit Quote:
01-16-2016, 05:59 PM | #3 |
Newbie Join Date: Dec 2015 Location: chattanooga
| Re: Battery Fit
Also be aware that your battery in question has a traxxas plug. I'm sure you saw that, I just wanted to point it out just in case. |
01-16-2016, 07:44 PM | #4 |
Quarry Creeper Join Date: Dec 2009 Location: Cape Cod
| Re: Battery Fit
I have an Onyx 2s hard case lipo that works in the bomber, but with the wires going out the end at an angle like the linked battery it is difficult to close the battery compartment without squishing wires. I went with a soft case 3s lipo in the bomber with the leads coming out on the end, it fits perfect without smashing wires.
01-17-2016, 05:37 AM | #5 |
Rock Crawler Join Date: Jan 2005 Location: The Hills
| Re: Battery Fit
A lot of info in here: Bomber Batteries I have a few runs on my hobbyking cheap 3s packs and they seem to do really well. Not sure I could get anything bigger in there either. |
01-17-2016, 08:00 PM | #6 |
Quarry Creeper Join Date: Feb 2012 Location: Verdi, Nevada
| Re: Battery Fit
No it will not. Just bought 3 of those for my yeti,killer batt, but it is to wide. I am looking for something to fit with a high discharge rate in the 4000 to 5000 mah
01-17-2016, 08:53 PM | #7 | |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Dimensions from there site is 133x42x27mm. | |
01-17-2016, 10:25 PM | #8 |
| Re: Battery Fit This is the same battery I was referring to in post #4, the Lectron pro 5200mah 50c 3s soft pack. I did have to swap the first one out since it was only charging to 4.02v, 4.10v, and 4.20v, but the second one is fine.
Battery Fit - Similar Threads | ||||
this battery fit a scx 10 | m1009cucv | Axial SCX-10 | 3 | 04-26-2012 10:09 AM |
Will this battery fit in the tray? | 4goodbuys2 | Venom Creeper | 8 | 12-24-2010 09:09 AM |
battery fit | superflex | Axial XR10 | 32 | 10-05-2010 07:11 PM |
Best battery pack fit? | rockassassin | Axial AX-10 Scorpion | 4 | 11-28-2008 11:04 PM |
What battery will fit in the stock GRC | wshipley | General Crawlers | 3 | 06-29-2007 01:53 PM |
