01-20-2016, 11:58 AM | #1 |
Rock Crawler Join Date: Dec 2015 Location: Charlotte, NC
| Bomber Drive Shaft Options
I see MIP drive shafts are sold as a pair with no Bomber set available. It doesn't seem they are sold individually to get 1 wraith and 1 yeti. What are the options?
01-20-2016, 12:09 PM | #2 |
Quarry Creeper Join Date: Oct 2010 Location: Pa
| Re: Bomber Drive Shaft Options
I'll let you know after I break the stock ones. From what I've read they seem to hold up fairly well.
01-20-2016, 12:13 PM | #3 |
RCC Addict Join Date: Aug 2013 Location: Missoula
Yeti rear, comes with the complete rear shaft. #14390 Front is Wraith male/female and two short 5mm ends. Wraith style for the small cross pin or AX10 style for the larger cross pin. Standard MIP X-Duty "Female" CVD™ - Super Shafty Standard MIP X-Duty CVD™ Bone - Super Shafty MIP CVD™ Rebuild Kit X-Duty - Super Shafty MIP 5mm replacment Hub - Super Shafty x2 All that is like $49. Or you can get a complete set for $55 and have 2 front shafts. Edit again... looks like a single ax10 shaft for $30 here. Yeti rear here. $68 plus shipping. Last edited by maslin; 01-20-2016 at 12:19 PM. |
01-20-2016, 12:25 PM | #4 |
Boom! That's what I was looking for. So the Ax10 shaft is same size as wraith front?
01-20-2016, 12:32 PM | #5 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Bomber Drive Shaft Options |
01-20-2016, 12:42 PM | #6 |
| Re: Bomber Drive Shaft Options The stock driveshafts have held up great for me. 3 rigs on 3s brushless Holmes power and not one has broken or even twisted on me in the slightest. I'm very curious to see how well they hold up on my new build with the monster Holmes 540XL. If that motor doesn't break them then I'll be very impressed.
01-20-2016, 12:46 PM | #7 |
Good to know. I am basically putting together an entire shopping list based on Harley's bulletproof wraith guide with similar stages. This is not a cheap hobby. Haha.
01-20-2016, 01:13 PM | #8 |
Not cheap at all but worth every penny!
01-20-2016, 01:15 PM | #9 |
The actual Wraith length, with a short end and a long end is just barely too long. 2 short ends bring it back so it doesn't bottom out. The scx10 shaft has 2 short ends with small screws, the ax10 shaft has 2 short ends with big screws.
01-20-2016, 01:26 PM | #10 |
Whats the MIP part number for short ends with big screw? I hate those tiny screw with 1.5mm head.
01-20-2016, 01:41 PM | #11 | |
| Re: Bomber Drive Shaft Options Quote:
The MIP side of it is universal, there is a short end with 5mm and small set screw, a short 5mm end with big set screws and a short 6mm end for upgraded trans outputs. The two with big screws are actually traxxas ends, but they work on any 5mm/6mm shaft. There's also 2 4mm traxxas through pins, a short one and long one. You need the short one. Last edited by maslin; 01-20-2016 at 01:45 PM. | |
01-20-2016, 03:56 PM | #12 |
I know that the cheaper version of the MIP's for the original AX10 will fit in a stock Wraith. Clearancing of the spur cover is required on a Wraith to fit the larger and shorter regular outputs. On a Bomber this should be a non-issue. There is a short section of slip that is connected at full droop. Proably less than 1/2". I think this is why the "Wraith" versions of the MIP's include the longer and slimmer (and smaller 3mm threaded) outputs. Even years later including mud/sand/snow usage and the slip is still fairly snug and actually slips easily while under torque. The joints however are not so tight anymore, but I keep putting barrels and Gunnar pins in them and drill another set of holes in the bone to keep them going. It's never pulled apart and become and issue so I considered the larger grubs and decreased operating angle where the tradeoff to increased slip overlap. |
Bomber Drive Shaft Options - Similar Threads | ||||
drive shaft options | krank22 | General Crawlers | 12 | 03-05-2014 05:01 PM |
so many drive shaft options? | steveo 561 | Axial SCX-10 | 2 | 05-16-2012 08:01 PM |
Drive shaft options tips | toy4crawlin | 1.9 Scale Rigs | 7 | 01-08-2011 10:06 PM |
wk drive shaft options | Burge | HPI Wheely King | 11 | 06-04-2008 03:25 PM |
drive shaft options????? | rcjeepbuilder | HPI Wheely King | 14 | 02-01-2008 03:11 PM |
