Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: Yoda's RR10 Bomber Build... B1B IFS!
Old 02-04-2016, 06:17 PM   #1
Default Yoda's RR10 Bomber Build... B1B IFS!
84yoda is offline   Reply With Quote
Old 02-04-2016, 06:17 PM   #2
Default re: Yoda's RR10 Bomber Build... B1B IFS!
New lights, rc4wd squadron light pods up front and gear head 4" koh light bar in rear.
Old 02-04-2016, 06:17 PM   #3
Fully extended.
Fully compressed, you can see no way near bottoming out the shock.
And upper links hitting the sway bar rod.
The fix, longer rod ends.
You can see the difference it made, I will run some rubber bump stops and will just barely clear sway bar rod and also fully compress. Im going to keep the limit straps in same place and it will limit fully extension but as it sits with trailing arms, it still has more travel then front.
Old 02-04-2016, 06:17 PM   #4
RC4WD metal hi lift. Best part is it actually works.
Carter fab hood and inner fenders (not in picture).
Old 02-04-2016, 06:18 PM   #5
Saved #4 lel
Sent from my XT1042 using Tapatalk
mattehmer01 is offline   Reply With Quote
Old 02-05-2016, 04:25 AM   #6
Great looking build how do you like the ssds and holmes servo?
ossipeecrawler is offline   Reply With Quote
Old 02-05-2016, 08:33 AM   #7
Thanks. I have not run either yet, but will hopefully soon.
Old 02-09-2016, 01:21 PM   #8
Looking good bro! Can't wait to see this thing when its done!
Terrible1 is offline   Reply With Quote
Old 02-09-2016, 01:58 PM   #9
What shocks are you using hard to tell in the pics
Old 02-09-2016, 02:09 PM   #10
Look like LOSIs.
SCREAMER is offline   Reply With Quote
Old 02-09-2016, 03:22 PM   #11
Thanks, I cant wait to run it too. Maybe you will change your mind about building one too.
Losi 4" shocks, they come on the losi comp crawler.
Old 02-09-2016, 04:13 PM   #12
Looks good!! I like how "clean" looking the SSD axles are!
I'm gonna have to try to add the window nets on my BGR chassis.
2-shot is offline   Reply With Quote
Old 02-09-2016, 10:54 PM   #13
Thanks. SSD ftw. Window nets are on ebay. They really complete the look of the chassis.
Old 02-09-2016, 11:00 PM   #14
I have a couple of the Lego nets. Is that what you used?
Old 02-09-2016, 11:42 PM   #15
Yup. 84mm x 84mm.
Old 02-29-2016, 11:13 PM   #16
Axles built.
Old 02-29-2016, 11:17 PM   #17
Looks damn good bro! Love those SSD axles!
Old 02-29-2016, 11:29 PM   #18
Thanks and ya the SSD housings are works of art. Just wait till you see who's panels showed up today.
Old 02-29-2016, 11:43 PM   #19
Damn! I already know! I'm going to have a lot of catching up to do but good news is... Mine is due to arrive tomorrow! Keep the pics coming!
Old 03-01-2016, 06:38 AM   #20
dbw
Which servo mount did you use on the ssd's for the HH500?
dbw is offline   Reply With Quote
Yoda's RR10 Bomber Build... B1B IFS! - Similar Threads
bilinvic's DMG IFS B1B Bomber Build bilinvic Axial RR10 Bomber 375 04-11-2024 07:56 AM
nfcrockett's RR10 Bomber Build nfcrockett Axial RR10 Bomber 28 06-27-2016 08:24 PM
My RR10 bomber build. mklemp2015 General Crawlers 2 04-07-2016 10:06 PM
