Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: OStewart's British Bomber
Old 03-29-2018, 05:51 AM   #21
Default Re: OStewart's British Bomber
If you go Mamba X i would spend a little more and grab a Holmes Hobbies puller pro motor.
If you stay with the hobbywing motor, grab a hobbywing esc like the max10 or the XR8, it would save cash.
Sent from my Nexus 6 using Tapatalk
Jboucher is offline   Reply With Quote
Old 03-29-2018, 05:57 AM   #22
To be fair they are similar prices for the motor, but I want a waterproof ESC really (hobbywing are not). The Servo I can waterproof at home using conformal coating.
I don't mind mixing and matching brands, and the new hobbywing motors are superb. The problem is getting the waterproof holmes motors is very pricey as I'm in the UK. I would need to pay import as Rcmart don't stock many of their models.
The only holmes one they have is the TrailMaster Pro BL 540 3300kv, but it comes with a 3.17mm shaft not 5mm like the Hobbywing.
ostewart is offline   Reply With Quote
Old 04-09-2018, 08:09 AM   #23
So I got my 2nd hand bomber, in excellent condition.
Imgur gallery here: https://oscarstewart93.imgur.com/all/
Here it is in bits, I am getting rid of the Hyrax tyres that are mounted on faultline beadlocks, and have on order some Pitbull Growlers U4 edition with chinese aluminium beadlocks.
I rebuilt the shocks with green slime to prevent them from leaking, 30wt oil in the rear, 20wt in the front.
I now need to order the vanquish sway bar, a good servo and a BEC.
Old 04-10-2018, 01:19 AM   #24
Nice shock holder! I’ve resolved to using deep well sockets for mine. They works surprisingly well and the CowRC Mat give them just a little added stability.
Sent from my iPhone using Tapatalk Pro
Siq6Six is offline   Reply With Quote
Old 04-10-2018, 08:01 AM   #25
As this is a secret bomber being kept from the other half, it lives at my office and my wrenching time is 1 hour per day (lunch break). That's also the time I will be using to run it.
Links made up, also need to swap some connectors out to XT60 and solder the relevant connectors to hook up a castle BEC.
Savox 1283 ordered.
Old 04-10-2018, 08:33 AM   #26
Beefing up the main parts before I think about clamping lockouts and shocks.
So far the list is quite long of bits I am getting/have:
Incision stainless link kit
Incision stock ratio HD gears
Incision spools
Axial universal front shafts
Savox 1283 Servo
Castle BEC
Holmes Hobbies TrailMaster Sport 550 21T
Robinson 10t pinion
Aluminium servo horn
Vanquish Trailing Arms
Vanquish one piece servo mount
Vanquish Currie Antirock sway bar
Chinese beadlocks
Pitbull RC Growlers U4 Edition
Crawler Innovations Double Deuce 5.5 comp cut, medium outer foam
Old 04-11-2018, 08:00 AM   #27
Fitted the links today, got to solder in my BEC and change batteries over to XT60.
Growlers arrived along with the Crawler Innovations 5.5 comp cut with medium outer foam, now waiting on my chinese beadlocks...
Old 04-12-2018, 08:00 AM   #28
Quick run in the warehouse after installing the BEC. Still waiting for plenty of parts for this. In the below pictures is pretty much stock apart from the incision links and the BEC.
Old 04-12-2018, 05:04 PM   #29
I killed my stock tactic servo 3 minutes after installing my Incision steering links just driving around on carpet in my living room! And I had the end points set short so it wasn't binding.
Plan for a servo upgrade
angrchair is offline   Reply With Quote
Old 04-12-2018, 11:13 PM   #30
Savox 1283 on the way already along with a bunch of other parts
Old 04-16-2018, 08:08 AM   #31
Oh how I love all those screws that go into chinese aluminium beadlocks, having to thread lock them all
Vanquish trailing arms, 550 21t motor and DMG spare relocation kit turned up too! Now need to mount the tyres to the beadlocks, install the trailing arms, motor and relocation kit.
Old 04-17-2018, 05:39 AM   #32
Got some beef to install. Servo also turned up, along with the sway bar so plenty to get installed now, and that will be it for a while until I have the funds for beef tubes and then I will think about clamping lockouts, c-hubs, knuckles and then maybe brushless motor and ESC. I'll still be running the stock ESC unless it goes up in smoke with the new 21t 550 motor.
Incision gears, Incision spools, Axial uni's
Old 04-17-2018, 09:48 AM   #33
All installed, now I need to run this thing!
The Incision gears are super smooth, even smoother than Axial HD gears!
Old 04-17-2018, 11:01 AM   #34
How is the quality of the wheels and how hard was it mount the tires?
jeepgod is offline   Reply With Quote
Old 04-17-2018, 11:12 AM   #35
I have the exact same model in matte silver so i'm interested in the bead retention as well.
Old 04-17-2018, 11:26 AM   #36
Easy to mount, excellent quality. I've used other Chinese beadlocks that are similar on a yeti with no problems.
Old 04-17-2018, 11:27 AM   #37
I've used some before on a yeti, they hold the tyres very well and I never popped a bead even at high speeds. They also hold proline beads very well
Old 04-18-2018, 07:51 AM   #38
So the motor isn't even getting warm on the 10/64 gearing, so I will go back to the stock 12/64 and possibly try 14/64 to get a little more top end out of it. Ok I was only running it for 40 mins but that's about all the time I ever really get to run it anyway.
One small casualty, a yeah racing servo horn...
Old 04-18-2018, 09:26 AM   #39
My bomber came with a cheap lightbar, one of the mounts broke as soon as I touched it.
Savox servo box (packaging) cut up and made into mounts not the tidiest of jobs but it's functional and I can take it off if it breaks.
Old 04-18-2018, 03:16 PM   #40
Looking good.
MI6 is listening in on this thread.
RiderZ is offline   Reply With Quote
OStewart's British Bomber - Similar Threads
british columbia Inclodneato Canada 158 01-02-2022 05:47 PM
NE British Columbia/NW Alberta Bro D Outside the US 1 06-11-2011 12:03 PM
calling all British,uk Tom94offroaduk Outside the US 5 01-28-2011 02:16 PM
