04-14-2016, 11:17 AM | #1 |
Newbie Join Date: Jul 2012 Location: Sweden
| ESC blinking red on brand new Bomber, no response at all.
Hi, I just bought a brand new Bomber. I turned on the transmitter and put in a charged battery. The ESC beeps twice for 2s LiPo, the steering servo moves a little and then the ESC just blinks red. No response on throttle or steering. All trims in middle. Any ideas? Last edited by ulsa; 04-14-2016 at 11:59 AM. |
04-14-2016, 11:28 AM | #2 |
Newbie Join Date: Mar 2016 Location: Hochatown Oklahoma
| Re: ESC blinking red on brand new Bomber, no response at all.
It sounds like a low battery or a reversed or bad connection Sent from my GT-P3113 using Tapatalk |
04-14-2016, 11:33 AM | #3 |
RCC Addict Join Date: May 2009 Location: Weston
Might be the throttle is not centered. Turn the trim knob untill it arms.
04-14-2016, 11:37 AM | #4 |
The battery is charged. I have tried with two separate batteries. I have tried turning the throttle trim but I am not sure I'm doing it right. Should I turn on the transmitter, plug in the battery and then slowly turn the trim? |
04-14-2016, 11:41 AM | #5 |
Yes. Hopefully thats all it is.
04-14-2016, 11:42 AM | #6 |
You can also pull the trigger a little at a time to for it to arm then turn the knob to find neutral.
04-14-2016, 11:45 AM | #7 |
Rock Stacker Join Date: Dec 2015 Location: Yucaipa
Is the red light on the transmitter? Mine out of the box would not turn on. Took it apart, wiggles some wires,and put it back together, and it worked Sent from my iPhone using Tapatalk |
04-14-2016, 11:54 AM | #8 | |
| Re: ESC blinking red on brand new Bomber, no response at all. Quote:
Yes, the light is on on the transmitter. | |
04-14-2016, 11:55 AM | #9 |
Have you tried to reprogram the esc? Sent from my iPhone using Tapatalk |
04-14-2016, 12:00 PM | #10 |
| Re: ESC blinking red on brand new Bomber, no response at all. |
04-14-2016, 12:30 PM | #11 |
The steering does work right? Does the light change at all when you puill the trigger?
04-14-2016, 12:55 PM | #12 | |
No change at all in the red blinking when I pull the trigger. | |
04-14-2016, 12:57 PM | #13 |
Sounds like you need to bind the receiver to the radio. http://manuals.hobbico.com/tac/tacl0325-manual.pdf |
04-14-2016, 01:04 PM | #14 | |
04-14-2016, 01:20 PM | #15 |
Warranty? These things have a warranty? Good luck! |
04-14-2016, 01:31 PM | #16 |
I got a bad ESC in my first RC, an RTR Spawn. Called Axial and a week later had a brand new one in my mailbox. Their customer service has always been great for me. I'd call them.
04-14-2016, 01:34 PM | #17 |
The only problem is that I won't see the car for a while unless it's the binding thing. They should be able to fix that during the day...
04-14-2016, 01:37 PM | #18 |
I would just do it yourself man. You need to learn how to work on this thing. This isn't the only time you'll ever have it torn apart. Mine's in pieces at least once a week.
04-14-2016, 01:54 PM | #19 | |
Why take the risk??? When I have used it I will fix it. Then it will probably be hard to claim warranty... | |
04-14-2016, 02:16 PM | #20 |
This is too much for you to try? It won't void the warranty. |
ESC blinking red on brand new Bomber, no response at all. - Similar Threads | ||||
AE -5 Esc blinking red light | Norcalwheeler | Axial Wraith | 8 | 01-13-2015 06:37 AM |
Axial AE-1 ESC problems. red/green blinking, does nothing. | fastline | Electronics | 1 | 11-10-2014 09:39 PM |
Got a blinking red/green LED on my ESC, but no power | Flatty | Electronics | 18 | 06-04-2012 08:28 PM |
Steering issue and Blinking Axial esc | Kanine38 | Newbie General | 0 | 02-12-2010 06:17 AM |
ax10 esc blinking! | obaskoba_420 | Electronics | 3 | 10-05-2009 08:20 PM |
