Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: Lower the Bomber for U4
Old 06-05-2016, 07:03 PM   #1
Default Lower the Bomber for U4
I just got a Bomber RTR and am going to use it for U4 racing. I have read a bunch of threads on stopping it rolling over but all of them seem to want to keep some crawling ability which I am not interested in. So things like weighted wheels etc which add rotating mass won't be for me.
So I am looking for some ideas on how to lower it as much as possible and the best way to widen and maybe even lengthen it slightly to 15" wheelbase as per U4RC 2.2 Comp regs.
- Shock recommendations?
- Shock mounting ideas / products to raise upper shock mounts and lower lower shock mounts?
- Best sway bars for front & rear?
- Any other recommendations for making the bomber more stable and difficult to roll over for U4 racing?
Thanks guys
byrnieman is offline   Reply With Quote
Old 06-05-2016, 09:22 PM   #2
Default Re: Lower the Bomber for U4
Definitely shocks for starters. Many are going to a 90 mm front and 100mm rear. I use the Axial sway bar and have no gripes about the stability it provides. Sure you could lengthen the front a bit but may be difficult in the rear with the available trailing arm options. There are a couple aftermarket shock mounts for the rear but haven't seen anything for the front yet.
Sent from my SM-N910V using Tapatalk
DowntownScience is offline   Reply With Quote
Old 06-06-2016, 08:38 AM   #3
Thanks - tell me about the Axial sway bar - is it a specific Bomber sway bar?? Front or rear?? Or are you using a yeti one or something??
I was hoping to get front and rear away bars - which ones should I be looking at?
Cheers
Old 06-06-2016, 08:46 AM   #4
Cheers
Yes, made by Axial specifically for the RR10 Bomber rear (ax31331). Seems to be really similar to the Yeti sway bar (Ax31113) except that the links that attach to the axle are much shorter.
Look at this on eBay http://www.ebay.com/itm/172230326572
Nothing for front as of yet.
Old 06-06-2016, 10:08 AM   #5
Axial, vp, ucfab and dlux have rear sway bars. For the front, ucfab sells sway bar mounts then use dlux universal sway bar.
84yoda is offline   Reply With Quote
Old 06-06-2016, 02:30 PM   #6
Yoda - Do you use the front?
Old 06-06-2016, 02:46 PM   #7
I did some work in my bomber, you can see it here: DenisLM's U4 Bomber build
it's waaay more stable than stock, but still rolls you push it too hard.
also if you make it longer, will be bad for crawling... so you need to choose your destiny.
DenisLM is offline   Reply With Quote
Old 06-06-2016, 03:12 PM   #8
Nope, I'm IFS now.
Old 06-10-2016, 06:32 PM   #9
Not interested in crawling as original post says. More than happy to trade off crawling ability for better stability at speed.
Are there upper shock mounts to raise the front & rear shock mounting positions like you would to lower a Wraith?
Old 06-10-2016, 06:33 PM   #10
Nope, I'm IFS now.
DMG B1B kit plus buying your own Yeti front end? Is this the only way to do this? Seems difficult & expensive??
Old 06-10-2016, 10:33 PM   #11
its probably cheaper to buy a yeti+b1b kit+bomber chassis from rpp lmao
microcrawlers is offline   Reply With Quote
Old 06-11-2016, 12:09 AM   #12
I'm running Proline Powerstroke on mine, Slash front (90 mm) up front and Slash rear (100 mm) rear with the softest springs Proline provides. Adjusted preload so that it stands with sag around 50/50. UC Fab 0.08 sway bar rear. Generally I like to run just a little toe out on the front axle. It is very stable at speeds and corners well. Never done any competitive racing though...
Odd-M is offline   Reply With Quote
Old 06-11-2016, 10:17 AM   #13
Smile Re: Lower the Bomber for U4
Thats what I did, since I didn't have a spare yeti to pull parts from.
Yes its expensive if you buy a bunch of upgrades and aluminum parts like I did. Not difficult but time consuming making a list of everything you need like parts, screws and there sizes.
Old 06-11-2016, 06:21 PM   #14
Don't suppose you could share that list of "everything you need" with me could ya?
Old 06-11-2016, 07:00 PM   #15
Post #65 shows all the parts I used. You want the screw types and there sizes too? Lol.
Im going to tear it down very soon and will go into detail about the parts I used.
http://www.rccrawler.com/forum/axial...r-build-4.html
Old 06-11-2016, 07:03 PM   #16
Says thread is invalid!
Old 06-11-2016, 07:25 PM   #17
Thats weird, it works for me. Well go to page 3 and its down a few. Let me know if it works that way.
Old 06-12-2016, 08:49 PM   #18
I've done the B1B conversion to my RR10 also Matt,
B1B Southern Hemisphere deployment
I didn't bring to the last U4 race but you can check it out any time.
Just note class wise it will move you from 2.2Comp with the Wraiths to 2.2IFS with the Yetis.
altd896 is offline   Reply With Quote
Old 06-13-2016, 01:35 AM   #19
A bomber ifs may not compete good with yetis. They will handle speed better. May be able to catch up in the rock section, but will be a interesting race to see.
If you don't have a yeti, a bomber ifs may be fun (and expensive)
I prefer to have two trucks and compete and two different categories with their one pros and cons.
Also for race purposes the yeti is way better to work on. The cage of the bomber and the access to the electronics are terrible if you compare side by side.
Old 04-11-2018, 11:08 PM   #20
My plan is to build custom brackets to lower the bomber. I bought a bunch of 110mm shocks that are built really well for a good price and don’t want to get rid of them. I plan on running dual shocks on all four corners. Will be easy to build it’s just drop brackets for the shocks I’ll post pictures when I get them done.
Jared.fritz33 is offline   Reply With Quote
Lower the Bomber for U4 - Similar Threads
Bomber Rear Lower Trailing Arms MD ENFORCER Axial RR10 Bomber 17 02-23-2021 06:58 PM
SDE RR10 Bomber LS1 & Headers - LOWER PRICE johnnyh66 Scale parts 2 10-08-2018 05:23 PM
