09-03-2016, 11:22 AM | #1 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
| Chump's U4 Bomber
After taking a 5 year break from comp crawling I've decided to give u4 a chance. This will be a slow, but steady build, and I'll try not to post to much of the boring stuff. Shout out to SMW for the awesome parts!! Axles have Incision lockers and ax10 trans is fully built. I will be upgrading parts as I go, I want to get the essentials first. Last edited by yotachump; 09-11-2016 at 04:48 PM. |
09-03-2016, 11:44 AM | #2 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
| re: Chump's U4 Bomber
Gonna give bashing a whirl huh? |
09-03-2016, 02:45 PM | #3 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
WTF?!?! Single shear uppers? How thick are those plates? |
09-04-2016, 12:58 PM | #4 |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
| re: Chump's U4 Bomber |
09-04-2016, 04:20 PM | #5 |
No way ill be driving a truck this tall. Looks like ill be needing to get some shocks and longer upper links. This is the way it will sit until I order some parts. Next update whenever I order the parts.
09-04-2016, 04:21 PM | #6 |
09-04-2016, 05:38 PM | #7 |
09-04-2016, 06:13 PM | #8 |
Flip the front smw mounts over, it'll drop the front down a little bit. Could also move the rear shock to the middle trailing arm holes...
09-04-2016, 08:48 PM | #9 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
Would it be possible to raise the shock mounts at the chassis? Use a little CF bracket maybe.
09-05-2016, 07:27 PM | #10 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
where did you get that SCX 10 transmission mount? thanks
09-09-2016, 05:49 PM | #11 |
Found some shafts that are .200" shorter and then took .150" off of the bodies. Much better Pictures are before and after. Last edited by yotachump; 09-11-2016 at 05:11 PM. |
09-21-2016, 04:23 PM | #12 |
| Re: Chump's U4 Bomber
I can't wait to crawl over your Bomber! |
09-23-2016, 11:16 AM | #13 |
| Re: Chump's U4 Bomber |
09-23-2016, 01:04 PM | #14 |
Rock Crawler Join Date: Jan 2008 Location: P-TOWN
Nice to see you back! Well you have a few weeks before the next race so lets finish this thing. What are you going to run for electronics?
09-24-2016, 07:56 PM | #15 | |
| Re: Chump's U4 Bomber Quote:
All I'm waiting for right now is the ESC, Wheels, foams and knuckles. Last edited by yotachump; 09-24-2016 at 08:00 PM. | |
09-26-2016, 08:22 AM | #16 |
Since you're doing the U4/bashing thing I have a set of new 2.2 C.I. D.W. tall foams if you need em.
10-02-2016, 04:04 PM | #17 |
Making some slow progress. it's sitting much better with the shorter shocks. Using some comp wheels I had made 5 years ago until I get something else. For the transmission, I added a Hot racing double up Traxxas Slash slipper clutch and am using an E-maxx disc brake pad for the slipper pad, should work pretty good, I hope. Last edited by yotachump; 10-03-2016 at 06:41 AM. |
10-02-2016, 09:31 PM | #18 |
Wheels look spot on. Aren't those wheel faces Ti? |
10-03-2016, 07:47 AM | #19 |
10-03-2016, 11:59 AM | #20 |
Chump's U4 Bomber - Similar Threads | ||||
Chump's CDW berg | yotachump | EnRoute Berg | 101 | 01-22-2017 02:31 PM |
Chump's 2012 CDW Build/Tech Thread | yotachump | Axial XR10 | 44 | 01-20-2012 09:08 PM |
Chump's 2011 comp rig build | yotachump | Axial XR10 | 85 | 10-30-2011 06:25 AM |
Chump's TTC Build | yotachump | 2.2 Scale Rigs | 59 | 02-01-2011 09:34 PM |
