Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: --Lets Go Topless --
Old 02-17-2018, 03:36 PM   #21
Default Re: --Lets Go Topless --
So...
This is the best i could do and i REALLY hate wiring.
This is connnecting front lights, light bar, Rear lights with brakes on/off and the servo on 3s
I need help
Jboucher is offline   Reply With Quote
Old 03-07-2018, 12:14 PM   #22
Originally Posted by MasteroFlego View Post
here's mine. yes the mounting of the ESC makes taking the cage off slightly more of a pain, just lift up the opposite side first. planning on replacing the stock rx box with a traxxas one.
What esc mount did you use and how is it mounted?
jeepgod is offline   Reply With Quote
Old 03-07-2018, 12:18 PM   #23
Traxxas VXL Rustler ESC plate, RPM Mamba X cage, and enough spacers to clear the cage, but not too high. It's attached to the shift servo mount.
Sent from my Nexus 5 using Tapatalk
MasteroFlego is offline   Reply With Quote
Old 03-08-2018, 11:47 AM   #24
I enjoyed reading your thread. I picked up that same ESC cage.
Derring-Do is offline   Reply With Quote
Old 03-09-2018, 07:08 PM   #25
Mamba X sensored with 3800kv , savox 1210 running 10/64 on 2s and 3s on 5.7 inch tires .
Sent from my ONEPLUS A5010 using Tapatalk
Exiwolfman is offline   Reply With Quote
Old 04-09-2018, 09:49 PM   #26
I'm real OCD with my wiring.
My lighting and winch stuff are all secured the cage, when I remove my cage I take off one side panel also, I can unplug my KOH lights from the harness, and 2 screws to remove my ESC switch, and everything comes apart, minimal effort.
angrchair is offline   Reply With Quote
Old 04-14-2018, 08:47 PM   #27
PileDriver is offline   Reply With Quote
Old 10-12-2018, 07:10 AM   #28
At the end I got it all sorted.
What I've got:
CC Mamba X (010-0155-00)
CC Brushless 1406-2850kV (060-0070-00)
CC Telemetry Link for Spektrum X-BUS (010-0148-00)
CC Quick Connect Duo (010-0149-00)
CC Castle Link V3 USB Programming Kit (011-0119-00 )
Spectrum SPMSR4000T receiver
I must admid, that I had to grind the bottom and the lid of the receiver box, to fit it all in.
Until now I have nothing to seal the wire inlet, but got the lid closed.
After enabling the live link and the aux mode in the programming of the Mamba it all runs now. Except sending the Motors temperature neither via the telemetry nor data log.
ToCrawl is offline   Reply With Quote
--Lets Go Topless -- - Similar Threads
Zuki topless sellenk Scale Videos! 4 07-10-2013 09:18 PM
Topless and bulletproof LowCrawl Losi Micro-Rock Crawler 62 09-07-2010 07:30 AM
