05-03-2018, 10:44 AM | #21 | |
| Re: To get or mot to get Quote:
The HobbyWing WP 1080 is an awesome ESC that, even if you take it out of your Bomber, I'm sure you can find a home for it later in another off road or even on-road car. My Tamiya M07 is ran by the 1080. | |
05-03-2018, 03:56 PM | #22 |
Rock Crawler Join Date: Dec 2010 Location: tracy
As long as the hobby shop has it. i will get a bomber kit this weekend. Any areas in the kit i should upgrade? Sent from my Moto Z (2) using Tapatalk Last edited by wcdfmt510; 05-03-2018 at 09:51 PM. |
05-03-2018, 04:47 PM | #23 | |
RCC Addict Join Date: Jun 2017 Location: Canada
Essentially : Beeftubes brass or aluminium Spool lockers (FI spools or Incision) Lockedup rc AR60 shims RPM revo rod ends with axial width brass balls Vanquish stage 1 Motor mount Fast eddy bearings Stainless screws Sent from my Nexus 6 using Tapatalk | |
05-05-2018, 07:23 PM | #24 |
On my way home from Sheldon's hobbies earlier today. 1 hour 10 min each way. Closest place i could find to me (tracy ca) didnt wanna wait 3 days from online Sent from my Moto Z (2) using Tapatalk |
05-06-2018, 03:43 PM | #25 |
6 1/2 hours later. Still not done. Is a pain on the ass to assemble this rig Sent from my Moto Z (2) using Tapatalk |
05-06-2018, 04:14 PM | #26 |
That's a lot done in 6.5hrs, though - you're ALMOST there!
05-06-2018, 04:23 PM | #27 |
Mine is "under construction" since august 2017... Sent from my Nexus 6 using Tapatalk |
05-06-2018, 05:10 PM | #28 |
Quarry Creeper Join Date: Apr 2009 Location: Long Beach
Just ordered my kit from LHS...will bick it up Friday and I enjoy the building part.... |
05-06-2018, 05:15 PM | #29 |
| Re: To get or mot to get |
05-06-2018, 05:17 PM | #30 |
05-06-2018, 07:37 PM | #31 | |
I've gathered enough upgrades to build a second one, and a while back lost my mind and also picked up an Ascender K10 so I could immediately go out and crawl for a while. It's now been upgraded a bunch, as well! | |
05-06-2018, 08:13 PM | #32 |
Is the rear axle supposed to be pointed slightly down? When suspension fully compressed, the shaft is level Sent from my Moto Z (2) using Tapatalk |
05-06-2018, 08:23 PM | #33 | |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
Sent from my Nexus 5 using Tapatalk | |
05-06-2018, 08:24 PM | #34 | |
Sent from my Moto Z (2) using Tapatalk | |
05-07-2018, 07:42 PM | #35 |
Question. Is the pinion gear thag comes with the bomber kit for 1/8th or 5mm shaft? Sent from my Moto Z (2) using Tapatalk |
05-07-2018, 07:43 PM | #36 |
1/8 5mm shafts are for 1/8 scale trucks Sent from my Nexus 6 using Tapatalk |
05-07-2018, 07:45 PM | #37 |
Ok. Just making sure. Since the hh trailmaster is 1/8th. Sent from my Moto Z (2) using Tapatalk |
05-07-2018, 08:40 PM | #38 |
Rock Crawler Join Date: Jan 2017 Location: DownUnner
Something is wrong as the tailshaft should be straight at full droop.
05-07-2018, 08:52 PM | #39 | |
05-08-2018, 10:55 AM | #40 |
Newbie Join Date: Jan 2018 Location: Victoria, B.C. Canada
If you lengthen your top links slightly you can adjust the pinion angle. Just unthread them a couple turns.
