01-02-2019, 08:02 PM | #1 |
Newbie Join Date: Dec 2018 Location: LOST Angeles
| no torque on crawling
I built a bomber and went with a losi 13.5t brushless and had to swap out a LRP esc to a hobbywing 35 amp esc.. I have the speed but when I go to crawl, it just feels like I don't have torque to crawl over anything, I can here the motor spooling but no transfer to the wheels.. Any suggestions on where or what to look for?
01-02-2019, 08:23 PM | #2 |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: no torque on crawling
My guess would be not enough power for a big 2.2 rig? 35amp seems really low but I don't know much about brushless systems Sent from my Pixel 2 XL using Tapatalk |
01-02-2019, 09:02 PM | #3 |
Slipper clutch too loose? 35A esc does sound small for a faster (which generally means it will pull more amps under load) 540 sized brushless in a relatively heavy car, maybe you're experiencing brown-out?
01-02-2019, 10:38 PM | #4 |
| Re: no torque on crawling Ill have to look to see what brownouts mean for the RC world, now that you mention the slipper clutch, I am wondering if thats what it is, it does sound/feel like a slipping issue.. getting access to the motor is a pain in the ass on these, is there an easier way to remove the cage? looking at it seems like i'd have to take apart quite a bit of the car to access it.. It was a kit already built from someone else, I just took the care over and jumped down the proverbial rabbit hole of rock crawling |
01-02-2019, 11:08 PM | #5 |
RCC Addict Join Date: Sep 2014 Location: Alberta
Yeah, electric motors don’t “spool”, so it’s likely the slipper clutch.
01-03-2019, 03:18 AM | #6 |
Rock Stacker Join Date: Oct 2017 Location: Australia
A smaller pinion gear will give it more torque but of course it will lose top speed also If you want to do lots of crawling you want a smaller pinion gear & larger spur gear, the gear ratios might simply be too high for what you are trying to do??? Check the pinion & spur gear tooth count & someone will let you know for sure if it is not setup for crawling |
01-03-2019, 07:33 AM | #7 |
13.5T motor, which is probably 2-pole, in a Bomber is probably enough, on its own, to make it lack torque.
01-03-2019, 10:28 AM | #8 |
| Re: no torque on crawling |
01-03-2019, 10:30 AM | #9 |
01-03-2019, 10:31 AM | #10 |
Also it's got a hobbywing 10bl120 120a esc in it.
01-03-2019, 10:37 AM | #11 |
Then it's 120amp not 35 which is fine for the truck. Check the slipper clutch, tighten it and give us an update. Sent from my Pixel 2 XL using Tapatalk |
01-03-2019, 11:52 AM | #12 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
I ran a 13.5t motor in my Bomber briefly. While it's got nowhere near the torque of other motors, it's still got substantially more than any brushed motor. As others have suggested, try tightening your slipper clutch. If that's not the problem, it could be stripped gears somewhere, but I'm putting my chips on the slipper.
01-04-2019, 02:41 AM | #13 | |
| Re: no torque on crawling Quote:
winner winner chicken dinner!!! Tightened down the slipper and she's crawling like nobody's business now.. Thanks everyone!!! | |
01-04-2019, 07:17 AM | #14 |
01-04-2019, 08:25 PM | #15 |
01-07-2019, 07:52 AM | #16 |
01-08-2019, 12:04 AM | #17 | |
You think I would benefit from running a slipper eliminator? | |
01-08-2019, 05:30 AM | #18 |
If you tighten the axial slipper all the way, it's basically an eliminator as long as the nut doesn't strip or back out. I feel it's safer to have a cheap weak point in the driveline, just like the plastic spur. Easy fix when you bind the truck and it can save expensive parts. Sent from my Pixel 2 XL using Tapatalk |
01-08-2019, 06:03 AM | #19 | |
I don't run slipper eliminators, but I do tighten my slipper clutches all the way down. I don't want my slipper clutch to slip. I'll take the change of breaking something, but honestly if you learn to let off the throttle in a bind you shouldn't have an issue. That's been my experience anyway. There are other people that think the slipper clutch is a safety net and they want it to slip before it munches any gears or breaks any parts. | |
01-08-2019, 07:53 AM | #20 |
I like having the slipper. On my Bomber, because that truck could end up airborne off of the occasional jump or tree root, it gives me a little peace of mind. On the trails, I rarely encounter situations where it slips, but when it does, it's usually because a wheel is bound up tight enough that the truck wasn't going to escape anyway. On my Gen7 I'm going to convert to a slipper assembly because that is the truck that my son uses. Point here is that if you've got a truck being used by a kid or somebody else who is inexperienced, a slipper is a good idea. |
no torque on crawling - Similar Threads | ||||
Mad Torque Colpar Crawling | QueadlunnRau | Videos! | 0 | 04-28-2018 11:03 PM |
ECX Temper Torque Twist Mod - Reduce torque twist | driftomaniacs | Scale Videos! | 0 | 05-14-2016 04:39 PM |
new to mad torque and rc crawling | mspiller21 | Superclass Crawlers | 49 | 06-14-2014 10:40 AM |
JR DS8711 ULTRA TORQUE SX SERVO 403oz/in TORQUE | 51504rock | Electronics | 1 | 06-12-2007 06:07 PM |
