05-23-2019, 08:54 AM | #1 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
| Dual motor bomber
Anybody interested in a dual 550/540 bomber? I just think it'd be really cool. And not two motors on the same transmission, but separate ones so you could set up dig and underdrive. Sent from my SM-G960W using Tapatalk |
05-23-2019, 10:00 AM | #2 |
Rock Crawler Join Date: Jul 2016 Location: Southern Oregon
| Re: Dual motor bomber
Would probably be much simpler to add a wraith trans with dig, and just change the axle gearing for OD/UD.... Sent from my SM-G970U using Tapatalk |
05-23-2019, 10:31 AM | #3 |
RCC Addict Join Date: Dec 2014 Location: So Cal
Interesting..... but is there room for everything involved? Using two Losi SCTE (I think that is the common scratch build TT mount of choice) motor mounts, AE/Thunder Tiger..... (you get the idea) with the motors up high, it may barely shoe horn in there. However, 2 esc, receivers..... also? How would you make it run without requiring 2 radios? Seems the electronics involved to make this happen are waaaaay above my paygrade. This a dream or a project?
05-23-2019, 11:02 AM | #4 |
You'd need two motors and two ESCs, but any decent modern radio with channel mixing should handle dig/overdrive/etc just fine. Stuffing everything on the skid would be the biggest hurdle for sure... Sent from my SM-G970U using Tapatalk |
05-23-2019, 06:43 PM | #5 | |||
| Re: Dual motor bomber Quote:
Sent from my SM-G960W using Tapatalk | |||
05-23-2019, 08:56 PM | #6 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
Would be interesting to see another shaft drive dual motor rig like that, theres a 1.9 tube chassis rig down here (on the other side of the country though) set up similar. Dual motor & esc with Tx throttle mixing exactly like a MOA rig, I think from memory (cos I can't find pics right now) it may be set up with 4ws also. All of the drive features of a MOA rig, front or rear dig/burn + 0-100% OD/UD, but the look of a scale shaft drive rig, I like it. Found link to pics Front Dig Last edited by altd896; 05-23-2019 at 11:00 PM. |
05-24-2019, 07:35 PM | #7 | |
Dual motor bomber - Similar Threads | ||||
Dual motor bomber engine mount?? | "MIS-TAKEN" | Axial RR10 Bomber | 28 | 10-16-2018 08:40 AM |
Scx10 dual motor dual trans beast rig | Dr.Newb | Axial SCX-10 | 0 | 08-02-2018 12:50 AM |
Bomber dual batteries?? | trascall10 | Axial RR10 Bomber | 19 | 05-28-2017 06:59 PM |
Dual motor 55T with Dual esc ae-5 mad crazy torque | Shan Newton | Axial SCX-10 | 24 | 05-09-2017 09:44 AM |
Airtronics M11 Settings for Dual Motor Dual Servo Crawlers | John Hallman | Electronics | 7 | 10-07-2010 11:34 PM |
