12-13-2015, 03:31 PM | #1 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
| Bomber Batteries
Wondering what everyone is using for batteries? I'm using a ZIPPY Compact 4000mAh 3s 60c and its REALLY tight in both length and height due to the wires touching the top or bottom of the battery box. It paces well with the sc4x 5.5t sensored through a MMP that I am running in mine. |
12-13-2015, 03:34 PM | #2 |
Quarry Creeper Join Date: Dec 2013 Location: Nunnelly, TN
| Re: Bomber Batteries
I use Turnigy 2200 mah 3s lipos. They give me plenty of run time. The only problem is they want to stick through the battery compartment. I cut a piece of plastic to put in front of the battery to keep that from happening.
12-13-2015, 04:42 PM | #3 |
Quarry Creeper Join Date: Dec 2011 Location: spokane
Hobby people 3200 4s still lots of room Just don't want any more weight up there.
12-13-2015, 04:47 PM | #4 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
Turnigy 2200mah 3s & venom 4000mah 3s!
12-13-2015, 06:33 PM | #5 |
RCC Addict Join Date: Jan 2010 Location: Vermont
2600 3s Hyperion 45c. Best batteries I have ever owned. Fit perfect with plenty of runtime. |
12-13-2015, 06:49 PM | #6 |
Rock Crawler Join Date: May 2007 Location: Salt Lake City
I'm running turnigy nanotech 3300 3s 65-130s.
12-13-2015, 07:16 PM | #7 |
Newbie Join Date: Dec 2015 Location: chattanooga
I would like to get a little more wheel speed . I've gone to a titan 550 21t and a 17 tooth pinion. I'm wondering if a nominal 3s lipo would help. I'm currently running a venom 5000 30c. Will the 3s burn up brushed motors if I am trail riding mostly? |
12-13-2015, 09:23 PM | #8 |
Pebble Pounder Join Date: Nov 2014 Location: philadelphia
I got the Duratrax Onyx 3S 5000 mah 25c which is an awful tight squeeze and takes a bit of work to close the lid to put the body clips in. I get a good 30 minutes running stock ESC and motor though. I also have vant battery 6500 mah 75c 2S that I'll use once I get my HH puller pro 3500kv and MMP esc installed. The vant will fit fine. I've raced with vant batteries since this summer and they've been great. I'm going to have to pick up an internal resistance meter one of these days to really measure the quality of these batts.
12-14-2015, 04:44 AM | #9 |
| Re: Bomber Batteries Might try the electronics section or your own thread instead of changing the topic in this one.
12-14-2015, 03:15 PM | #10 |
Rock Crawler Join Date: Jan 2005 Location: The Hills
Those of you posting stuff from hobbyking.com, please post a part number to make it easier to find, thanks! My bomber is enroute and looking for packs now.
12-14-2015, 04:35 PM | #11 |
Newbie Join Date: Nov 2015 Location: Colorado
Do you have any measurements of the hard case batteries that fit? How about accurate measurements of the battery compartment?
12-14-2015, 04:49 PM | #12 | ||
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: Bomber Batteries Quote:
Maybe 5 1/4" long, but then you're running out of room for the wires. No taller or wider. | ||
12-14-2015, 06:21 PM | #13 |
What I run and its really tight @ 43mm and 148mm. ZIPPY Compact 4000mAh 3s 60c Lipo Pack (AR Warehouse) |
12-16-2015, 01:14 AM | #14 |
Newbie Join Date: Dec 2015 Location: mainland
picked up the tower bomber kit and got this battery which they suggest TowerHobbies.com | Duratrax Onyx LiPo 3S 11.1V 5000mAh 25C Soft Case Star the battery door and hood is tough to close it just seems really really tight to get the pins back in not a fan how hard is it to get the hood and door closed and pins back in ? the other dimensions are OK and a snug fit though |
12-21-2015, 05:07 PM | #15 |
Picked up a couple of these tonight: Turnigy 3600mAh 3S 20C Lipo Pack (AR Warehouse) I de-cased one of my 3s 5000mah hard packs just to see if I needed 3s on this truck. Answer , YES! The 5000 would fit but I had to wedge it in there and it's really way to big for the compartment. I'll report once they come in. |
12-21-2015, 05:20 PM | #16 |
Newbie Join Date: Nov 2015 Location: Freeport
I'm running chepo Vant Battery 3s 4200 30c batteries I picked up on sale off fleabay. Really tight but they do fit with a little wire finagling and they last a long time!
12-21-2015, 08:03 PM | #17 | |
Newbie Join Date: Dec 2015 Location: USA
12-21-2015, 08:08 PM | #18 | |
Pebble Pounder Join Date: Jan 2013 Location: Between a rock & a hard place in North Texas
| Re: Bomber Batteries Does it fit well? Or is it a tight fit? How much run time are you getting? Quote:
12-21-2015, 10:19 PM | #19 |
| Re: Bomber Batteries |
12-21-2015, 11:25 PM | #20 |
Pebble Pounder Join Date: Jan 2014 Location: San Jose
Running SMC 3200 4s 60c. Little tight width wise but they just fit.
Bomber Batteries - Similar Threads | ||||
Tedo's Bomber | tedo | Axial RR10 Bomber | 3 | 02-08-2016 07:47 AM |
Bomber axel | Mitchell72 | Axial RR10 Bomber | 2 | 12-12-2015 09:18 PM |
Hawaii Bomber | BakedMopar | Videos! | 0 | 12-12-2015 07:35 PM |
Backwoods Bomber | Duuuuuuuude | 1.9 Scale Rigs | 153 | 06-11-2012 08:41 AM |
