Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: Clutch spur gear plastic spacer
Old 06-07-2020, 05:23 AM   #1
Default Clutch spur gear plastic spacer
The plastic spacer AX31108 is the same size as a 5X11x4 bearing.
Can this be done OR is the plastic used for a reason? see no mention of a upgrade and surprised not inc if needed. Any info or opinion please?
Gazzalene is offline   Reply With Quote
Old 06-07-2020, 08:30 AM   #2
Default Re: Clutch spur gear plastic spacer
If you are referring to the bushing in the middle of the spur gear, yes you can. Any of the aftermarket spur gears actually come with a bearing.
Sent from my Moto Z (2) using Tapatalk
FlatLander72 is offline   Reply With Quote
Old 06-07-2020, 12:34 PM   #3
Thanks for the info,did not know if plastic was needed for any reason when tightening the clutch.Will bung a sealed bearing in there.
Clutch spur gear plastic spacer - Similar Threads
Change spur pitch to 32 and slipper clutch ? Chris1975 Axial AX-10 Scorpion 7 01-26-2016 09:28 PM
Slipper clutch/ spur gear meanbgreen Newbie General 6 09-02-2011 08:20 AM
Rs10 plastic Spur gear seal set upgrade? Macmanthizz Redcat Crawlers 24 08-20-2011 11:16 AM
Spur gear adapter spacer BigD74 Tamiya TLT Crawlers 2 03-28-2006 08:22 AM
