Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: Motor esc questions
Old 02-21-2021, 11:37 AM   #1
Default Motor esc questions
Hey all. So I have a Scx10iii also. For my Bomber, I purchased a Holmes Hobbies, puller pro I think, 4100kv.
I also purchased a Hobbywing brushless esc not axe,.
I thought the motor was a sensorless, to match the esc.
Bench test shows they work together. What am I going to be missing without the sensored configuration?
REDdawn6 is offline   Reply With Quote
Old 02-21-2021, 11:57 AM   #2
Default Re: Motor esc questions
You'll probably miss low speed control
Sent from my GM1917 using Tapatalk
Mletchworth is offline   Reply With Quote
Old 02-21-2021, 12:05 PM   #3
I am thinking , I should pony up for a Mamba x...
Old 02-21-2021, 01:06 PM   #4
Yep, good idea
Old 02-21-2021, 01:12 PM   #5
You will have less low end control. So it will not crawl very well. Or I should say less slow than a sensored system. If you plan on bashing this setup more than crawling, you will be fine.
Sent from my moto z4 using Tapatalk
FlatLander72 is offline   Reply With Quote
Old 02-21-2021, 01:42 PM   #6
I was planning on a mix of both.
Old 02-21-2021, 02:20 PM   #7
If you drive it like you are trying to win the KOH race. You will be fine. If you want more technical control, it would be a good idea to look into the Mamba X controller. It has settings to take advantage of both low end control and balls to the wall speed.
Old 02-21-2021, 03:27 PM   #8
Thanks for the replies. I will grab a Mamba x
Motor esc questions - Similar Threads
Sidewinder esc and 5700 motor or Traxxas vxl 3s esc with brushless motor? THE CRAWLER KING Newbie General 6 08-22-2010 07:10 AM
single motor esc or dual motor esc jwo Electronics 0 01-20-2010 11:42 PM
