05-22-2009, 05:49 AM | #21 |
Pebble Pounder Join Date: Apr 2007 Location: Near Oxford, UK
yeh, the part numbers are rubbish, labled wrong on the parts trees. but ah well, i went by the pictures and all worked out I'm really happy with the speed, just right |
05-22-2009, 03:48 PM | #22 |
Rock Crawler Join Date: Jan 2007 Location: San Clemente, CA.
Hurry up, lets see the d90 part |
05-23-2009, 10:30 AM | #23 |
The body is shipping out on monday!
05-23-2009, 10:36 AM | #24 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
Looks like this is gonna be a cool build. Can I ask where you're getting the body from? |
05-23-2009, 10:37 AM | #25 |
From a bloke who gets them from the manufacturer... email this guy: laihonwai@netvigator.com |
05-26-2009, 03:16 PM | #26 |
Body on order!!! |
06-02-2009, 11:21 AM | #27 |
Body in UK!
06-03-2009, 12:54 PM | #28 |
Well i finally got the body through from Hong Kong . so much better than having to paint a lexan body! I have yet to put the wing mirrors on yet, or the bumpers. The above photo shows the only real fault with the body, the windscreen wipers are on upside down. (no they dont rotate :( ) The last could of pics are the body and interior jsut sat on the chassis. Need a little trimming to get the body lower which will be done once i know how i am going to attach the body... ...suggestions on body mountings? Also, I knew before i ordered, but the wheelbase is slightly too long for the body, what are the options for shortening it slightly? |
06-03-2009, 01:08 PM | #29 |
Rock Crawler Join Date: Apr 2009 Location: Pa
Nice body there. I'd probably mount it with velcro, shure wouldn't want to drill holes in it. Shortening the links is easy especially if you have access to a lathe. Just face off one end of each tube to shorten them and extend the thread in the tube if needed with an M3x.5 tap.
06-03-2009, 01:18 PM | #30 |
hadnt thought of that. any ideas on how much i should remove from each end of the links? (i'll do the rears only i think.) i need to loose about 1/2" of wheelbase.
06-03-2009, 03:49 PM | #31 |
Not really shure how much needs to come off. I'd probably take 8mm off the bottom 2 tubes, assemble them and see what the wheelbase is. Once you get the wheelbase close eye up about how much you need to take off the top links. Remember removing material is a lot easier than putting material back on. |
06-03-2009, 05:21 PM | #32 | |
Newbie Join Date: May 2009 Location: Everett
Just wondering, what kind of velcro would you use. Obivously I would need something that is strong so the body don't come off. | |
06-03-2009, 05:34 PM | #33 |
Quarry Creeper Join Date: Jan 2009 Location: Hagerstown
I'm building the same truck. To shorten the wheelbase I use SWX lower links with a 7mm spacer for mock up. For upper links I used stock AX10 uppers and the wheelbase is real close. Maybe 2mm short. Good luck and don't paint yours the same color as mine lol. |
06-04-2009, 05:23 AM | #34 |
got a link to the SWX lower links? i take it these will be a bolt on job? would bending the standard link shorten them (for the straight distance axle to skid)? how easy would it be to bend the standard links? Cheers |
06-07-2009, 06:02 AM | #35 |
Would it work to use some of the grey posts that axial have here: http://www.axialracing.com/ftp/ax10o...s_spacers.html would it work if i used some of these (once i have worked out the link length i need)? or have you guys got any other ideas that i can do? Ideally i want a stock looking setup thats a bolt on job. |
06-07-2009, 01:34 PM | #36 |
could someone with an SCX check something for me. do you think i need to reduce the front links by 13mm to give me an overall 0.5'' wheelbase reduction?
06-28-2009, 11:59 PM | #37 |
Newbie Join Date: May 2008 Location: Belgium
I think i saw that the wipers are not attached to the body, surely there must be a way to flip em around and glue 'em back? ( for mounting the body you could also go with strong magnets ) grtz! |
06-29-2009, 12:18 AM | #38 |
I wanna be Dave Join Date: Feb 2009 Location: Cowtown, USA
I would love to have land rover body like that, know of a good place to order? BTW, nice rig! |
06-29-2009, 05:14 AM | #39 |
Newbie Join Date: Jan 2009 Location: europe
Nice this is exactly what i had in mind to build was thinking to buy the axial sxc10 and that body allready is stored in my rc garage, the wipers is something that must be wrong because mine (2) are the wipers also mounted upside down. Maybe they use it for wipe the platters that fly up from the road héhé (UK people) |
07-24-2009, 11:10 AM | #40 |
I joined the Band! Join Date: May 2006 Location: Between a rock and a hard spot!
I bought mine on ebay and it came from hong kong.
