12-16-2011, 07:05 PM | #1 |
Quarry Creeper Join Date: Apr 2011 Location: Waimanalo, Hawaii \m/
| Trans making noise??
I need some help my trans is making a ticking noise and i dont know what it is. It just started making that noise when i installed the rr gears. Tonight im going to take it apart but i needed some suggestions to what it could or mite be. Thanks in advance. -Noah |
12-16-2011, 07:15 PM | #2 |
RCC Addict Join Date: Jul 2011 Location: Orlando
| Re: Trans making noise??
Might be the bearings inside the trans. I would take it apart and lube or wd-40 the bearings.
12-16-2011, 07:27 PM | #3 |
Quarry Creeper Join Date: Oct 2008 Location: Reno, NV
I'm having the same problem with mine. Since my crawler began its life as a AX10 from a cousin. Which i then converted to a SCX10, i don't know what that tranny has been through and ive taken it apart a few times and checked the pinion gear mesh but i couldn't figure it out? Ill take another look tomorrow if i get a chance.
12-16-2011, 07:44 PM | #4 |
RCC Addict Join Date: May 2010 Location: So. Charleston. Wv
Does it have a slipper clutch? With the RR gears install did you get a spur My ax had a ticking noise and it was the spur gear had a few teeth knocked down |
12-16-2011, 08:50 PM | #5 |
Quarry Creeper Join Date: Jul 2009 Location: Back from vacation!!!
I'm with Phantom- Burred spur or something between a tooth. It don't take much to tick.
12-16-2011, 09:33 PM | #6 |
RCC Addict Join Date: Feb 2011 Location: York
Use WD 40 to clean a bearing, maybe, but don't ever use it as a lube unless it's for something open where you can re-apply like a door or cabinet hinge. There are far better lubes available as WD40 is more a penetrant and a very light lube mix.
12-16-2011, 09:40 PM | #7 |
So its just probably just the bearing.
12-16-2011, 09:54 PM | #8 |
Maybe...probably not. Bearings will sometimes tick, but usually a tick can likely be attributed to a gear. You said you installed new gears...what gears? Spur and pinion? Idler etc?
12-16-2011, 10:39 PM | #9 |
Pebble Pounder Join Date: Feb 2008 Location: 808
Hey Noah, maybe the spur has a tiny nick or check your pinion, maybe you have slight contact between the spur and setscrew. Goodluck!!
12-16-2011, 11:13 PM | #10 |
^^^^ you going tommorrow to maks for scaleing?? i can show yo whats wrong. and i only installed the internal rr gears and it only started makeing the noise when i flipped my truck of the curb and it hit the ground pritty hard.
12-16-2011, 11:22 PM | #11 |
| Re: Trans making noise?? like Pau Hana said, look for a nick in the spur.
12-16-2011, 11:29 PM | #12 |
I wanna be Dave Join Date: Dec 2008 Location: ?
Do you have the Robinson Racing Outdrive Diff Lock Gear AX10 one piece?
12-17-2011, 12:36 AM | #13 |
Yes it's a one peace and I will check if there's a nick in the sper
Trans making noise?? - Similar Threads | ||||
RC4WD Winch making noise and shaking. | 70duncan | Electronics | 3 | 02-18-2011 09:30 PM |
Servo making a funny noise | Ryan_m_c | Losi Mini-Rock Crawler | 3 | 06-18-2010 10:38 AM |
Hitec 7955TG making noise | werewolf1983 | Electronics | 16 | 01-06-2010 07:21 PM |
Brushless making noise? | lt1wrangler | Electronics | 7 | 09-04-2007 11:01 PM |
