12-28-2011, 01:14 PM | #1 |
Rock Stacker Join Date: Dec 2008 Location: East
| MOA convert to SCX10
O.K. I am a newbie, I have built myself a 2.2 clod crawler/basher, but when I posted pics of it I was informed it was not SCALE. My Torsion Crawler I had no idea how hardcore these scalers are! After looking at many threads in the 1.9 and 2.2 scaler sections, I have decided I need to build one for myself. The closest thing to a scaler I have built so far is putting a 72' chevy body on my son's rs10. I know it is moa but the axles are not as wide as the clods. Now I have a scx10 roller chassis coming A reedy 23 turn spec motor w/ 24 tooth 48p pinion rooster speed control (no drag brake) 7cell nimh pack I am going to he LHS and was wondering if a 14 tooth pinion would give me enough wheel speed, or should I try the 24 tooth? I have done plenty of searching, but no one runs my esc/motor combo, so don't be too hard on me. Also have a new bright rockcrawler.com body I might use. Any thoughts on the hard plastic body? I have heard they are brittle. I have had more than my share of addictions, this one seems the most harmless. I once read that if you have a habit you can't share, you should probably quit it. I have no problem at all sharing rc crawling with my son. Great site, thanks in advance for the help! Last edited by EL PHANTASMO; 12-28-2011 at 01:20 PM. Reason: looney |
12-28-2011, 02:31 PM | #2 |
Newbie Join Date: Sep 2011 Location: Beaufort
| Re: MOA convert to SCX10
I cant answer on the motor/ESC question, but I have a Hilux hard body and have bashed it on its fair share of rocks and it hasn't cracked or damaged at all. I prefer them over the lexan bodies. I have 4 lexan bodies for my drift car and all of them crack after 1-2 hits. Also, you can stiffen lexan bodies with aluminum tape if you get one of those bodies, I had to with my drift bodies. Hope this helps!
12-28-2011, 04:33 PM | #3 |
Thanks, I am glad to hear that. The new bright body is much more detailed than dingo body I have. GCM |
12-28-2011, 04:44 PM | #4 |
RCC Addict Join Date: Oct 2011 Location: Brighton UK
Good on ya, imho the 2 best hard shells are the land rover d90 or the new bright jeep unlimited. The shells though probably require a bit more work getting a decent paint job done, but once you have it really shows. Proline do a jeep unlimited and it drops straight onto a honcho chassis with no wheel base alteration. Either of the hard-shells will require wheel base to be shortened or lengthened. But they are worth it!! |
12-28-2011, 08:32 PM | #5 |
Thanks for the encouragement! Can't wait till my chassis arrives, I am really getting stoked about this build! I am thinking about o.d. green. The flat paint job will be easier than high gloss. |
MOA convert to SCX10 - Similar Threads | ||||
ax10 to scx10 cheap convert ?any suggestions | nissan7 | Axial SCX-10 | 3 | 09-15-2010 06:01 PM |
What is needed to convert AX10 to Scale SCX10 | neuro242 | Axial SCX-10 | 5 | 08-22-2009 08:23 PM |
convert a AX10 to a SCX10 | mint355 | Axial SCX-10 | 16 | 06-28-2009 02:17 AM |
I want to convert my AX10 to an SCX10 | speedemall | Axial AX-10 Scorpion | 17 | 02-08-2009 02:50 AM |
