01-11-2012, 05:39 PM | #1 |
Newbie Join Date: Nov 2005 Location: loudon
| honcho vs. dingo
What makes a better trail rig ? Does one have more bodies to match the wheelbase ? Does the longer help or hurt the honcho ?
01-11-2012, 06:07 PM | #2 |
Rock Crawler Join Date: Nov 2009 Location: poteau
| Re: honcho vs. dingo
man that's like what's better ford or chevy! they are both great trucks, i prefer the honcho tho. i like the extended wheelbase which does help in climbing. it seems around here that the honcho has more body choices. the 12.5 inch wheelbase seems to be what most manufactures hit when they build bodies. now when you get into hard bodies like ripping a new bright body off, they seem to fit the dingo better.
01-11-2012, 06:16 PM | #3 | |
RCC Addict Join Date: Jul 2011 Location: Orlando
| Re: honcho vs. dingo Quote:
Now for bodies...... there are actually more that fit the Dingo then the Honcho. Dingo Body 11.3" WB ProLine Wranger 2 Door JK ProLine Jeep Cherokee 92' ProLine Blazer 2 Door ProLine Comanchee New Bright JK 2 Door Mudslinger New Bright Ford/Chevy/Dodge Trucks 1/10 scale Honcho Body 12.4" WB There are more then these but the only 2 I have actually fit on it without issues. ProLine 4 Door Unlimited JK New Bright Unlimited 4 Door JK (WB 13.5") | |
01-11-2012, 07:25 PM | #4 |
Rock Crawler Join Date: Sep 2011 Location: Southern Utah
| Re: honcho vs. dingo It all depends on your terrain and driving style. I have one of each, and in some obsticles the honcho is better and some the dingo is better. (mine are actually a hilux and jeep, but you get the point). The shorter wheelbase won't get high centered as easily, and the longer wheelbase won't tip back as easy. So it really depends. In general my honcho wheelbase performs better. I'm mostly into slickrock crawling which is fairly smoot and rolling compaired to crawling through a pile of busted up cement.
01-11-2012, 10:27 PM | #5 |
Pebble Pounder Join Date: Dec 2011 Location: Monterey
with the ability to make your own links, you can change your wheelbase to fit mst bodies in most situations
01-12-2012, 06:44 AM | #6 |
Newbie Join Date: Jan 2012 Location: Sarasota
Dingo! Jus cause thats what I bought! Lol!
01-17-2012, 02:10 PM | #7 |
Thanks for the info guys
01-17-2012, 03:24 PM | #8 | |
Pebble Pounder Join Date: Dec 2010 Location: Gallatin
01-17-2012, 07:05 PM | #9 |
RCC Addict Join Date: Oct 2011 Location: Brighton UK
I'd say the honcho, the longer wheelbase helps, and I've recently done a new bright jeep which meant lengthening the wheel base some more and it really does help.
01-29-2012, 09:11 PM | #10 | |
Rock Crawler Join Date: Mar 2011 Location: hampton
02-25-2012, 06:50 AM | #11 |
Newbie Join Date: Feb 2012 Location: USA
The Honcho is only available as RTR right? What if we want to bring the Dingo kit to Honcho specs, what needs to be changed?
02-25-2012, 08:41 AM | #12 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
Lengthen rear links, mover shock towers back, and that's about it. Check your rear driveline to see that they won't over extend and come apart. You might need another combination of the supplied shafts.
02-25-2012, 09:18 AM | #13 |
Pebble Pounder Join Date: Nov 2010 Location: 419 area
a proline ford f-650 body for an emaxx fits the honcho almost perfectly. thats what i ran on mine.
02-25-2012, 09:48 AM | #14 |
Rock Crawler Join Date: Aug 2008 Location: Bristol Va.
I had a Dingo and sold it, I now have 3 Honcho's and a Wraith, love the longer wheelbase. My last project is a Proline 73 Bronco body for a Revo, fits perfect.
02-26-2012, 11:21 AM | #15 |
Quarry Creeper Join Date: Apr 2006 Location: SLC, Utah
I bought the Dingo kit so I could get the XJ body, An I like the stock bumpers on the dingo. I knew if I wanted to change to a longer wheelbase I just have to make longer rear links.
02-26-2012, 11:53 AM | #16 | ||
Newbie Join Date: Dec 2011 Location: Sacramento
Just get the honcho size links. They are universal. | ||
02-26-2012, 12:14 PM | #17 |
Quarry Creeper Join Date: Dec 2008 Location: NW ATL
I prefer a kit because (1) I want to make sure it's built right (2) Building provides an important level of appreciation & understanding for maintenance, upgrades, & repairs - you don't get that knowledge with a pre-built machine |
02-26-2012, 12:39 PM | #18 |
Quarry Creeper Join Date: Jan 2006 Location: North Charleston
| Re: honcho vs. dingo |
07-21-2012, 10:45 PM | #19 |
Newbie Join Date: Dec 2011 Location: ...
i am having the same problem right now, if i get a dingo, and honcho links driveshaft and shockmounts, then i can pretty much switch that stuff out and have a honcho, or switch back to a dingo?
07-21-2012, 11:00 PM | #20 |
Quarry Creeper Join Date: Jun 2009 Location: Oslo, Norway
honcho vs. dingo - Similar Threads | ||||
Dingo or another Honcho???? | AsILayDying | Axial SCX-10 | 21 | 08-26-2011 01:49 PM |
honcho vs dingo | LUNAticCrawlingCrew | Axial SCX-10 | 11 | 07-26-2011 04:13 PM |
Honcho or Dingo?? | geekfreek95 | Axial SCX-10 | 11 | 02-23-2011 10:07 PM |
honcho vs. dingo | geekfreek95 | Axial SCX-10 | 2 | 02-16-2011 05:27 PM |
Honcho TR VS. Dingo | BOBO_XLT | Axial SCX-10 | 15 | 12-05-2010 07:45 AM |
