01-12-2012, 05:32 AM | #1 |
Newbie Join Date: Jan 2012 Location: United States
| Axial SCX10 wheelbase questions
Can anyone help me with what length bars (pipes) make up which wheelbase for the Axial SCX10 Frame? I see so many different lengths and nobody seams to cross reference wheelbase with the length. Any help here will much appreciated.
01-12-2012, 09:04 AM | #2 |
Rock Stacker Join Date: Jul 2011 Location: Lansing
| Re: Axial SCX10 wheelbase questions
Ok, the dingo(axial's land rover) has an 11.4" wheelbase. The short wheelbase belongs to this truck. the honcho(appearing to be a tacoma with a cage) has a 12.3" inch wheelbase. So by logic the honcho links are longer than the dingo's. I hope this helped. |
01-12-2012, 09:50 AM | #3 |
Rock Crawler Join Date: Aug 2011 Location: dallas
SCX10 TR ALUMINUM LINKS UPGRADE SET SCX10 TR Links Set AX30549 - SCX10 TR Links Set - 11.4" / 290mm AX30550 - SCX10 TR Links Set - 12.3" / 313mm SCX10 TR Aluminum Links Upgrade Set Upgrades your SCX10 TR to all aluminum links Includes the hardware and links needed to upgrade to a 3 link OR 4 link setup using the 4 link mount included with the TR series of product Two different wheelbases available 11.4” (290mm) WB – Fits Dingo body and other short wheelbase bodies 12.3” (313mm) WB – Fits Trail Honcho Body and other longer wheelbase bodies Part numbers and EAN Codes Part # EAN Description Price MSRP AX30549 877493008277 SCX10 TR Links Set - 11.4" (290mm) WB $70.00 $50.00 AX30550 877493008284 SCX10 TR Links Set - 12.3" (313mm) WB $75.00 $54.00 I think the front and rear lower short wb is 91mm and upper posts are 7x20 and 7x60 the 12.3 wb lowers are 6x98 for the front w 7x25 and 7x60 post for upper 4 link and rear is 6x106 lowers and 7x35 7x60 posts for upper 4 link Last edited by jcsaxial; 01-12-2012 at 10:03 AM. |
01-12-2012, 03:30 PM | #4 |
Thanks, exactly what I was looking for.
02-16-2015, 07:30 PM | #5 |
Newbie Join Date: Feb 2015 Location: Rock Hill
When you say 7x35 7x60 you really mean 7x95? Why 2 numbers?
02-16-2015, 07:50 PM | #6 |
Quarry Creeper Join Date: Mar 2014 Location: Rogers, MN
Axial's aluminum link sets use 2 smaller posts for the upper links, and the one lower pipe for the lowers The 12" wheelbases of the G6 and Deadbolts use, at least for the lowers, the 98mm lower pipes front and rear. So you'd want to use the same on the back and front as the front of the 12.3" wheelbase. |
02-17-2015, 04:17 PM | #7 |
Newbie Join Date: Nov 2014 Location: Little Rock
I don't know if it was a mistake, but I grabbed two sets of the AX30550 12.3 link sets, one for each Deadbolt we have, because they are listed as compatible on Axial's site. I must say Axial needs to work on their instructions. Do I put the 106mm on the front or rear? I have currently installed them on the front, with the longer uppers, and it pushed the tires forward. I even had to remove the cross brace in front of the servo for clearance. Should I move them to the back and put the 98mm in the front?
02-18-2015, 06:23 PM | #8 |
The 106 is for the rear. With it up front it will give you a better approach angle.im thinking about stretching the front or doing something with the bumper to better my rubicon 12.3wb
02-21-2015, 12:05 PM | #9 |
| Re: Axial SCX10 wheelbase questions |
08-23-2015, 03:47 PM | #10 |
Newbie Join Date: Oct 2013 Location: Apex
Ok right this might be a newb question but what the advantage of there is one of converting to the shorter wheelbase?
08-23-2015, 04:00 PM | #11 |
08-23-2015, 06:42 PM | #12 |
Tighter turning and better break over angle (less likely to high center on an obstacle).
08-24-2015, 09:40 PM | #13 |
Thanks, I love the mighty 83rd body but I didn't want to sacrifice too much to get it to fit right
Axial SCX10 wheelbase questions - Similar Threads | ||||
Wheelbase Questions? | Mighty1 | General Scale Talk | 1 | 10-13-2011 08:31 PM |
Newb questions about Axial SCX10 | dtm4192 | Newbie General | 10 | 05-17-2011 06:25 PM |
Axial SCX10 Wheelbase? | jasons36 | Newbie General | 0 | 03-28-2010 08:50 AM |
axial scx10 questions | poop | Newbie General | 10 | 05-19-2009 08:29 PM |
Scale WK wheelbase questions | 4x4dodge | HPI Wheely King | 2 | 04-28-2007 07:13 PM |
