01-20-2012, 07:12 PM | #1 |
Pebble Pounder Join Date: Oct 2011 Location: Kansas City, MO
| SCX10 Transverse motor mounting?
With all the issues of torque twist when crawling or tooling around, has anyone ever considered a transversely mounted motor? Obviously the cost to design a transmission to accommodate such a setup would be rather expensive to produce, so perhaps there is something already available in other kits? I'm thinking maybe something from a Tamiya kit since Tamiya loves bevel gears and compact transmissions, but everything I can think of is molded into the chassis. Ideas?
01-20-2012, 07:16 PM | #2 |
| Re: SCX10 Transverse motor mounting?
Torque twist is due to the occurrence of the (driveshaft) pinion gear trying to climb the ring gear. Not which direction the motor is mounted.
01-20-2012, 07:18 PM | #3 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
Its already been done, Im pretty sure its called a mirrored tranny or something like that.
01-20-2012, 07:20 PM | #4 |
| Re: SCX10 Transverse motor mounting? |
01-20-2012, 07:23 PM | #5 |
| Re: SCX10 Transverse motor mounting? True that plays a role, but I'm not so sure it's the only cause. There's a lot of weight being spun inside a motor and maybe transverse mounting might alleviate some of it?
SCX10 Transverse motor mounting? - Similar Threads | ||||
Mounting a Ax10 onto a Scx10 | -mud- | General Crawlers | 53 | 09-04-2011 07:46 AM |
jk mounting on scx10 | slashkiller | Paint and Body | 4 | 12-13-2010 09:03 PM |
AX10 Motor Plate/Motor Mounting Problems | md7989 | Electronics | 8 | 11-25-2010 01:30 PM |
Need help: mounting gilux on scx10 | homer | Axial SCX-10 | 5 | 03-10-2010 02:12 PM |
Motor mounting on the SCX10 | luv2ridemx | Axial SCX-10 | 1 | 02-17-2010 11:38 PM |
