01-29-2012, 01:32 PM | #1 |
Rock Stacker Join Date: Dec 2011 Location: pell city
| more lift
i want to get more lift out of my honcho how can i achive this... shocks lift kit tires etc
01-29-2012, 02:12 PM | #2 |
RCC Addict Join Date: May 2011 Location: Utah County
| Re: more lift
lift is over-rated, especially in scale rc. keep it's center of gravity low and you'll be more happy with how it drives. if you wanted a monster truck you shoulda got a txt-1 or somethin. hehe. but if all you care about is that "lifted" look, then turn down the pre-load ring all the way on your shocks, and get some 2.2 proline swampers.. but be ready for it to tip over a lot and probably break 3x as many driveshafts/axleshafts than you would if you keep it low n slow. good luck |
01-29-2012, 03:20 PM | #3 |
Rock Crawler Join Date: Oct 2010 Location: Abbotsford BC
| Re: more lift
the most effective lift is larger tires, since they raise the axle housing. Then rather that lift the suspension more raise the body instead. I have the bumpers screwed on top of the mounts rather than through them to match the body. |
01-29-2012, 03:22 PM | #4 | |
Pebble Pounder Join Date: Dec 2011 Location: Monterey
| Re: more lift x2 he said it man, first thing i did when i got mine was lift it, because i had some 2.2 tires from a previous build and wanted to run them, i ran into so many issues, with driveshafts breaking and my drivetrain binding, i put it back stock and am in the process of just upgrading parts but keeping it 1.9 and am much much happier with how my build is going, get you some baja claws there big 1.9's and a happy medium for the jacked up look with out breaking stuff! Hope this helps! Quote:
01-29-2012, 03:50 PM | #5 |
| Re: more lift
Thanks guys n I'm just wanting the look of it I don't really crawl I do more mudding and I have 2.2 dealers on it now just looking 4 more cause the bodies hitting n rubbing and is their longer shocks I can buy n which lift is the best
01-30-2012, 05:41 AM | #6 |
Newbie Join Date: Jan 2012 Location: Loudon, TN
| Re: more lift Axial SCX-10 Honcho & Dingo LIFT KIT! RC Crawler SCX10 Truck Parts! ^This, or just make it yourself. |
01-30-2012, 05:52 AM | #7 |
| Re: more lift
that dont seem hard to make at all wut could i use to make it n wut r my options on shocks
01-30-2012, 12:43 PM | #8 |
Quarry Creeper Join Date: Aug 2007 Location: Pacific Northwest
| Re: more lift
I just XR10 shocks and 2.2 to get more lift on my Cherokee. Here it is with just the XR10 shocks. Here it is with the XR10 shocks and 2.2 tires and wheels Last edited by t9dragon; 01-30-2012 at 12:50 PM. |
01-30-2012, 02:21 PM | #9 |
| Re: more lift
Imma try them also n Wut mm r they
more lift - Similar Threads | ||||
High-Lift Mods (steering servo, track bar and body lift) | thefordmccord | 1.9 Scale Rigs | 5 | 07-17-2009 11:41 PM |
Hi-Lift Transmission Lift....need advice | BladeMech | 1.9 Scale Rigs | 10 | 06-19-2009 01:46 PM |
lift | geekfreek95 | General Crawlers | 5 | 05-01-2007 11:48 AM |
Hi Lift y0! | EeePee | Videos! | 23 | 01-22-2007 06:41 PM |
DX 6 on a Hi-lift | Grape Ape !!! | Electronics | 6 | 10-03-2006 09:46 AM |
