02-02-2012, 10:50 AM | #1 |
Newbie Join Date: Jan 2007 Location: Alexandria
| Anybody know how to Center the driveshafts/tranny?
I hate the angle of the driveshafts coming off of the trans on my Honcho. Does anyone know how to center the transmission? or is there a trans out there with center outputs? The only one I know of is a wheely king trans, but that puts the motor way too high up. I just want the angle of my driveshafts to go straight to the pumpkins... Any ideas?? I need help!! Thanks guys! |
02-02-2012, 12:04 PM | #2 |
Pebble Pounder Join Date: Dec 2011 Location: Monterey
| Re: Anybody know how to Center the driveshafts/tranny?
put wraith axles in it, and it will fix your problem also give it a wider stance, with more stability, they have off-set chunks they stock axial trans works well, im not certain if it will line up exactly, but i do know that if it doesnt you can clock the trans 180* to help with torque twist, it should line up better than with the stock honcho axles, you can also switch out the honcho trans for the wraith trans, the wraith trans has upgrades available for dig also, if that floats your boat, hope this helps some
02-02-2012, 12:32 PM | #3 |
I thought about switching out the axles, but I kinda like the stock stance and width with the stock axles... I was wondering about the wraith trans.... It has the same mounting holes, but I can't tell if the tranny output shafts would be centered on the SCX10 skidplate... that's what I'm trying to accomplish. I may just drill 4 new holes and slide the whole tranny over to straighten out the driveline. Waiting to see what Axial support has to say... |
02-02-2012, 12:52 PM | #4 |
RCC Addict Join Date: May 2011 Location: Utah County
there's literally no need to straighten out the drive shafts. driveshafts are made to transfer rotation to the axles at less-than-straight angles. lots of 1:1's driveshafts aren't not in the center of the chassis. there's no difference in side to side angle differences from up and down angle differences. driveshafts are meant to take it. if not, there wouldn't be universal joints in them.. they would just be straight solid cylinders that bolt onto each end. if you're worried about the u-joints wearing out fast then buy some wraith driveshafts. they can take more extreme angles. (btw you dont need to worry about them wearing out fast, but if you do worry about it, then get some wraith shafts) if you're just worried about the "looks" of a crooked driveshaft.. then i cant help ya. but making a new skid plate out of delrin and drilling the tranny mounting holes in the center of the new skid plate would center your output shafts and driveshafts. although this will put your motor hanging outside of the chassis rails, which will off-balance your rig. but hey, if centering your driveshafts is worth it to you, then go for it. |
02-02-2012, 02:11 PM | #5 |
Quarry Creeper Join Date: Jul 2011 Location: Seattle
heinie_21 pretty much covered what i was going to say. What is behind the desire to center them? Is it just an OCD thing? It is made like this so the motor does not have to be strait up (WK style), or too far off either side. Changing this is going to do 2 things, centering your driveshafts for no reason to make you feel better, and mess up how your vehicle is weighted, making odd torque twist on other fun issues.
02-02-2012, 02:39 PM | #6 |
Quarry Creeper Join Date: Jan 2006 Location: North Charleston
one thing you can do is flip the tranny mount around, this will not center the shaft, but it did make the angle less extreme and has the added advantage to allowing you to mount the wraith interior in a honcho.
02-02-2012, 02:52 PM | #7 |
Toss in a summit tranny
02-02-2012, 09:34 PM | #8 |
| Re: Anybody know how to Center the driveshafts/tranny? This would not change the angle, it would just move the same angle to the other side.
02-03-2012, 02:17 AM | #9 |
Pebble Pounder Join Date: Oct 2011 Location: Kansas City, MO
Could take some aluminum sheet and cut it to fit the top of the skid plate for support (don't remember how the "webbing" is laid out on the plastic off the top of my head), and then drill new holes through both. Offsetting the tranny so shafts straighten out and the motor hangs off the side could allow you to mount your battery pack in the middle opposite side of the tranny from the motor. This will probably make the angles worse for the yokes, though, as the tranny outputs being off to the side help alleviate them.
02-03-2012, 03:06 AM | #10 | |
| Re: Anybody know how to Center the driveshafts/tranny? Quote:
02-03-2012, 03:09 AM | #11 | |
I wanna be Dave Join Date: May 2006 Location: akron
02-03-2012, 03:59 AM | #12 | |
As a matter of fact, I can imagine a pretty sweet FOFF truck by modifying the frame rails and doing just what the OP is thinking. Would allow for straighter shafts, meaning less stress on the yokes and shaft's ears. | |
02-03-2012, 05:46 AM | #13 |
Quarry Creeper Join Date: Aug 2009 Location: here
Get a creeper tranny. And the more angle you have on the drive shafts the more torque twist you can get from it. That's why the GC-3 and a few other comp chassis have the motor hanging out the side of the chassis.
02-03-2012, 07:37 AM | #14 |
Thanks for all the input guys... Yeah, maybe it's just an OCD thing, but I'd like the shafts on one plane instead of two... they're already angled down towards the pumpkins vertically... the other plane being horizontally towards the centered pumpkins... I really wish Axial would make an axle with an offset pumpkin for the front of a SCX10, for scale purposes... but then the shaft would probably hit the links... I just wanted to try to mod it because I am always tinkering with this thing, like the rest of you, trying to build it like I like it... I know the shafts are strong enough, and that it was designed this way on purpose.. just sayin I don't like it that way, that's all... Technically, everyone here could have bought the thing and left it completely stock, it performs perfectly... it was designed to... Last edited by tamiyatim; 02-03-2012 at 07:37 AM. Reason: typo |
02-03-2012, 07:40 AM | #15 |
I see RC4WD makes a delrin skid plate for installing an R2 tranny... may get one of those and drill some new holes in it... Or, I may just keep the $30 bucks and get me an aluminum bumper mount... not sure yet... Till then, I'll sit back and enjoy seeing my "Digger King" featured in Readers Rides in RC Driver... WOO HOO!!! I feel famous!! |
02-03-2012, 09:06 AM | #16 | |
02-03-2012, 02:23 PM | #17 |
| Re: Anybody know how to Center the driveshafts/tranny? I meant reasons that actually relate to how this helps the truck. I am OCD as well, so my brain is making me think it is simply about the symmetry that he is asking.
02-03-2012, 02:52 PM | #18 |
Newbie Join Date: May 2011 Location: Lake Winni
Venom Creeper trans?
02-03-2012, 06:14 PM | #19 | |
02-04-2012, 09:57 AM | #20 |
Pebble Pounder Join Date: Apr 2011 Location: scranton
| Re: Anybody know how to Center the driveshafts/tranny? |
Anybody know how to Center the driveshafts/tranny? - Similar Threads | ||||
Traxxas 1/16 center driveshafts | 02hawk | Axial SCX-10 | 8 | 01-22-2012 04:11 PM |
center driveshafts | boostedg60rado | Axial AX-10 Scorpion | 30 | 03-21-2010 05:55 PM |
? about center driveshafts | rider12693 | Team Losi Comp Crawler | 4 | 01-05-2010 03:25 PM |
3 Racing or MIP Center Driveshafts | Paul97 | Losi Mini-Rock Crawler | 7 | 11-27-2009 11:57 PM |
clock tranny, center driveshafts, reduce torque twist | mulepic | Axial AX-10 Scorpion | 9 | 09-10-2008 04:59 PM |
