02-15-2012, 08:04 PM | #1 |
Pebble Pounder Join Date: Nov 2009 Location: pennsylvania
| Poor mans panhard !!
In the first pic you can see how I bolted the servo plate fast through the frame and shock hoop.mounts pretty flush. Here is a little better view for you Front side, I made my drop bracket out of galvanized sheet metal works great and doesnt flex that much. just enough on roll overs so it don't get bent to hell Mounted my pan hard to the pumpkin works alittle nicer then all the way across and doesn't bind at all Hope this helps a few people on a budget! |
02-16-2012, 12:13 AM | #2 |
Rock Crawler Join Date: Oct 2011 Location: Co,Cork..Ireland
| Re: Poor mans panhard !!
This is a great How To , ( you should add it to the SCX Tips and Tricks Thread ) I was just asking another member how he mounted his servo this way... Why do they call it Panhard ? Sean Last edited by West Cork Basher; 02-16-2012 at 12:16 AM. |
02-16-2012, 01:46 AM | #3 |
Pebble Pounder Join Date: Sep 2009 Location: joppa,al
i see that your shock hoops look leaned back toward the transmission, did you flip sides(right hoop on left side frame, left hoop on right side frame) with them to get it that way?
02-16-2012, 02:14 AM | #4 |
| Re: Poor mans panhard !! |
02-16-2012, 02:47 AM | #5 |
just noticed because it gave me an idea on how to lower a brat body on a build i'm doing. lol 1st build i'm posting on here. http://www.rccrawler.com/forum/axial...ss-so-far.html |
02-16-2012, 07:20 PM | #6 |
Yea i just flopped them thats all, and I when I get a little free time I will, its free and looks just as good!
02-16-2012, 07:44 PM | #7 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
The panhard won't work correctly as the suspension cycles. The panhard should be at or near the same angle of the drag link. If you can get it closer to the correct angle I'm sure you will notice a huge improvement. You just have such a ridiculous amount of drop on it. And the bracket shouldn't flex either. You want it to stay rigid otherwise it will affect the geometry as well.
02-16-2012, 09:00 PM | #8 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
id also like to point out there there is no need for a panhard bar on a 4 link, or triangulated 3link, and chances are useing it in a dule triangulated 4 link its probably just goin to bind and do no actual good
02-16-2012, 09:11 PM | #9 | |
| Re: Poor mans panhard !! Quote:
once again this is an rc, I agree but you know what I had a 4 linked jeep xj. and it was streetable and did awesome out the mtn. but you better believe I was running a trac bar. otherwise I touched each burm and the house next to it | |
02-16-2012, 09:41 PM | #10 |
You may feel that it cycles fine but the concept is the same fullsize and rc, if you ever drive an rc that has a properly set-up panhard then you'll notice a difference. And why would you run a panhard bar on a jeep that's 4 linked? It's pointless. And what are you doing that you'll snap steel or a chunk of alluminum etc? I drive hard but I haven't managed that one. And I've been doing both fullsize and rc for quite a while and I am still learning, hell I'll never stop. So before you go saying that we're both "completely wrong" Think it through. I'm not meaning to sound disrespectful and wasn't before either. What you said came across that way.
02-16-2012, 10:16 PM | #11 |
Quarry Creeper Join Date: Dec 2011 Location: The land of snow
02-16-2012, 10:43 PM | #12 |
well if you ever had a actual true 4 link on a real vehicle you would realize without a track bar it pushes the body instead of the tires unless your using a hydraulic ram on the axle, it was also a dd. so I cant be turning my wheel and the only response was a frame twist. that whole trac bar needs to be inline is true but the cycling thing isnt. we've had rigs with "correct"bars and it would hit, sometimes depending on what your flex and angles it will not match your steering arm..
02-16-2012, 10:58 PM | #13 |
I wanna be Dave Join Date: May 2006 Location: akron
02-16-2012, 11:21 PM | #14 | |
Pebble Pounder Join Date: Oct 2011 Location: loveland
first off im sure your "4 link" in your 1:1 isnt a true 4 link. probly has like the rusty long arm kit with the upper links actually attached to the lower links, so yes in that case a panhard is needed. A panhard is not needed with a properly set up 4 link. and same does go with RC | |
02-16-2012, 11:22 PM | #15 | |||
Rock Crawler Join Date: Aug 2010 Location: Socal
Also I recommend extending the panhard out a bit. The closer it can match the drag link length the better. Maybe try fabbing a simple mount to the 2 holes above the link mounts on the housing. Still simple just better geometry. Quote:
02-16-2012, 11:55 PM | #16 | |
02-17-2012, 12:54 AM | #17 | |
RCC Addict Join Date: Aug 2010 Location: wherever paypal sais.
MY .02 With a triangulated 4 link you can't run a panhard or trac bar cause it will bind the link geometry as the panhard is trying to push/pull on the axle side to side and the tri 4link wants it to be centered. With a tri 4link If the using a steering box on the chassis you'll get bump steer out the a$$ unless suspension travel is minimal. If you run a 4 link in which all the links run parallel then a panhard/trac bar is required to keep the axle from swinging side to side. And at the same time eliminating that "chassis push" everyone is speeking of. But at the same time might as well get rid of 1 upper link and just go with 3.(but this is where a panhard with a 4link could be used) The reason you get chassis push with a 4link is b/c the links are all mounted at the skid or near it, then you have 5 feet of chassis where the steering box is located. and depending on how long ur links are and durability/strength of ur chassis itself will depend on how much the chassis will want to "push" (b/c of the lenght of chassis between where the steering box is and where the "axle" is mounted to said chassis. Now at the same time with axle mounted hydro this is not an issue. Nor is bump steer which is why we run the panhard/trac bar setup in the first place. And with a 3link w/ panahrd it is 100% critical to have your panhard and drag link running same lenght and parallel to one another. This doesent mean the panhard has to be "straight" it can bend to contour the pumpkin as long as the end points on both ends of both bars match end rant my pnahard setup for less than 15$ done the correct way. made easy only have to make 2 brackets left bump full right left bump full left right bump full left right bump full right right bump steering centered full bump full extend take notice that absolutely NOTHING touches ANYWHERE in the susp cycle. heres how to the right way. and it doesnt look hideous like the OP's (yes i said it) axle bracket(always the same) chassis bracket(this will change depending on servo location just modify to suit your build) Last edited by kaneohecrawler; 02-17-2012 at 01:19 AM. | |
02-17-2012, 12:56 AM | #18 |
Rock Crawler Join Date: May 2009 Location: Hillsboro, OR / Kapolei, Hi
I'd like a nice vid from the OP that shows the rig during full suspension travel. Looks like the axle will shift laterally unless the shock travel is short. Vid will put an end to the argument.
02-17-2012, 01:07 AM | #19 | |
but it would end up moving laterally in a bad way. a panhard is designed for the axle to move to the side but only enough so that the panhard and draglink travel on the same arc. which is what eleiminates bumpsteer. but im not argueing wit him i was stating facts. lol Last edited by kaneohecrawler; 02-17-2012 at 01:29 AM. | |
02-17-2012, 01:14 AM | #20 |
I'm more looking to squash the "u did it wrong/i did it right" thats going on. I've used your design to make mine. Finished tonight actually. I've also studied 1:1 and RC builds to get length and angel tips. My panhard mounts from directly behind the ball end on my servo mount down to nearly directly behind the ball end on my knuckle. Axle doesn't shift at all!
Poor mans panhard !! - Similar Threads | ||||
Poor Mans Pearl | retrofive | Paint and Body | 5 | 02-26-2012 08:44 PM |
Poor mans 6-cell split pack......lol | KID | Electronics | 3 | 11-13-2008 04:59 PM |
Poor Mans Berg | Chris_The_Battery_Man | Tamiya Clod Buster | 24 | 08-06-2008 05:38 PM |
Poor Mans Wheel Weights | DirkDigler | Tires and Wheels | 35 | 04-16-2008 11:13 AM |
Poor Mans 2.2 Wheel Mods | Jeeper Creeper | Tires and Wheels | 7 | 04-30-2007 02:29 PM |
