02-16-2012, 07:18 PM | #1 |
Newbie Join Date: Jan 2012 Location: United States
| My first crawler build
Here is what I have been working on for 2 months now. I have had alot of fun getting to this point. Started off with an Axial SCX10 basic kit, but I guess that was a mistake after all. I think I used the frame rails and rear end housings. Pretty much it is either upgraded, after market, or fabricated to get were I am. I did install a DIG unit on the front axle to make it capable of 2WD or 4WD just as full scale. I want to get some good pictures of it in its envirenment and of course some videos crawling. I guess all in due time. Still a few items to add.
02-16-2012, 07:32 PM | #2 |
RCC Addict Join Date: Sep 2010 Location: Apollo Pa
Wow! That is bad azz what body is that? Is that a Wraith interior? Sent from my VTAB1008 using Tapatalk |
02-16-2012, 07:36 PM | #3 |
| Re: My first crawler build
it is the HPI body modified and yes that is a wraith front interior and custom built back interior and roll cage. I got the idea for the wraith interior from Mechanic
02-17-2012, 05:36 PM | #4 |
heres an update with outdoor pictures
02-18-2012, 05:09 PM | #5 |
Rock Crawler Join Date: Sep 2011 Location: Southern Utah
That looks way good Good work on the interior
02-18-2012, 05:57 PM | #6 |
Thanks guys. Got to take it out today and initiate it. Several scratches later I was having a blast. It really performs as I hoped, way to much fun. |
02-18-2012, 06:29 PM | #7 |
Rock Stacker Join Date: Jan 2012 Location: Elkton, MD
WOW Looking real good |
02-18-2012, 09:04 PM | #8 |
Pebble Pounder Join Date: Dec 2005 Location: W. Richland
Looks pretty good, although your steering doesn't look happy. I really your interior. Did you pull it out of something and modify it or did you build it all yourself?
02-19-2012, 06:01 AM | #9 | |
| Re: My first crawler build Quote:
The interior started off a Wraith interior. I fit it for the jeep and then built the back protion from styrene. The roll cage is brake line welded together. | |
02-19-2012, 09:28 AM | #10 |
Quarry Creeper Join Date: Aug 2009 Location: here
Damn that's nice. It makes me want to dust off my old rubi lid.
02-19-2012, 09:57 AM | #11 | |
Thats a really cool idea with the Wraith interior. How wide is it? The more I see your interior the more and more I dig it. | |
02-19-2012, 10:47 AM | #12 |
OK, understand why you said what you did. Here is my theory, right or wrong. The aluminum bar I bought for the front mounts the servo point where I have it located. I can move it out to the normal location with no big deal, and may do jusy that after playing with it some. This will cut the angle down in half of what it is. I played with 3 link, 4 link and a panard bar. No matter what it seams to limit travel or free range of the suspension in one way or another. For a panard bar to work perfect you need to have side play in the axle, may be small but you need some. These little trucks have zero side play no matter what link system you go to. Therefore no matter what the panard bar causes binding when the suspension moves. I would rather have full travel suspension rather than zero bump steer. In all my playing around the only way to get both perfect are to mount the servo back to the axle. All that said, on to the interior. The interior comes 6-1/2" wide at the floor. Actually I got the idea of the interior from Mechanic, another RCCrawler member. He put one in a Honcho and it looked outstanding. |
02-20-2012, 11:23 AM | #13 | |
The 3 link took everything off the top of the axle and allowed it to move freely without anything hitting the frame. I do lose maybe 1/8" of up travel, but my down travel is only limited by the actual travel of my shocks themselves. | |
02-20-2012, 01:39 PM | #14 |
Quarry Creeper Join Date: Jan 2006 Location: North Charleston
looks great, my only real problem with it is the grill and headlight covers kinda bugs me.
02-20-2012, 01:46 PM | #15 |
| Re: My first crawler build |
02-20-2012, 01:57 PM | #16 |
| Re: My first crawler build just some constructive criticism, something does not look right about them being there. but its your truck not mine. as i said though looks good just may look better if the grill were a paint finish instead of mirrored.
02-20-2012, 03:26 PM | #17 |
Quarry Creeper Join Date: Nov 2010 Location: Dade City
Love the look of your rig are those gmade shocks
02-20-2012, 05:28 PM | #18 |
Rock Crawler Join Date: Oct 2011 Location: minot
the mirrored aluminium is a piece available through quadratec for 1:1 jeeps... the ONLY thing that really kinda caught my eye in a wierd way was the gloss fenders. they look sahara edition-ish (not my fav but thats opinion) i woulda painted em satin black to mimic the bolt on plastic a little better. other than that ONE stinky little opinion that is a seriously KILLER BUILD! |
02-21-2012, 04:01 AM | #19 | |
02-21-2012, 06:23 AM | #20 |
Quarry Creeper Join Date: Jan 2011 Location: Kyle TX
| Re: My first crawler build If you use Tamiya rubber black it will give you the effect. Even sprayed from the inside. Used it on my Cherokee and turned out real close to 1:1.
My first crawler build - Similar Threads | ||||
Jeep scaler build and comp micro crawler build | droopmodmrc | Losi Micro-Rock Crawler | 1 | 12-25-2012 12:34 PM |
maxx crawler build Never even driven a crawler | jh1985 | Traxxas Crawlers | 2 | 07-21-2011 02:04 PM |
Axial AX-10 Scorpion 1/10 Rock Crawler Kit Build, Chapter 2 "The Mod Build" | JAM MaxAmps.com | Axial AX-10 Scorpion | 42 | 06-06-2008 10:00 PM |
Practice build before I build a real crawler. | jm8881 | General Crawlers | 46 | 03-13-2005 09:21 PM |
TXT Crawler.... Stone Cold Crawler... Full Tube Scale build | RockSpyder | Tamiya Txt-1 and Juggernaut | 6 | 12-14-2004 09:40 AM |
