02-18-2012, 10:29 PM | #1 |
Pebble Pounder Join Date: Feb 2012 Location: tampabay
| 3 Racing Winch
3 racing winch installed on the stock Honcho bumper 1st you will need 4 2mm x 10 Socket Head Cap screws ( Dubro ) part# 2113 2nd remove the aluminum center plate tape the face of the plate this will protect the plate when trimming out the opening for the roller on the face of the winch. The front bumper has 4 marks drill with small drill bit. 3 remove the 4 screws on the bottom winch mounting plate this is the same location the the Dubro 2113 will be installed. trim plate and reinstall all corresponding components. At this time of the install you will have to find a location for the control module and power supply. |
02-19-2012, 10:43 AM | #2 |
Pebble Pounder Join Date: Nov 2011 Location: london, kentucky
| Re: 3 Racig Winch
do u have to run its own personal battery just to use the winch, i have the same winch and really dont want to have to run 2 battterys on it? thanks
02-19-2012, 10:51 AM | #3 |
Quarry Creeper Join Date: Jan 2012 Location: My house
Just program it on channel 3 on ur receiver and radio I run only 1 battery and the 10amp BEC so I get enough power. Just my .02.
02-19-2012, 10:55 AM | #4 |
| Re: 3 Racig Winch
You would have to have a pig tail right? To by pass all that button and stuff
02-19-2012, 11:39 AM | #5 |
| Re: 3 Racig Winch
I did install a 7.4 2 cell just for the winch here are some pics |
02-19-2012, 11:42 AM | #6 |
| Re: 3 Racig Winch
remote winch battery |
02-19-2012, 12:54 PM | #7 |
| Re: 3 Racig Winch
Ok I am happy with this for now next is installing it to the Dx3s 3 Racing Winch Axial Honcho - YouTube |
02-19-2012, 07:09 PM | #8 |
Quarry Creeper Join Date: Feb 2011 Location: Princeton Illinois
| Re: 3 Racig Winch
the stock winch controller is no good...it will eventually fail..mine did after 2 times using it...i would suggest using something like this... No Drift Winch Controller! (using 3 position transmitter channel) im using one of these and it works perfect...no need to run en extra battery either |
02-19-2012, 08:06 PM | #9 | |
| Re: 3 Racig Winch Quote:
02-22-2012, 09:38 AM | #10 | |
02-22-2012, 10:00 AM | #11 |
Newbie Join Date: Oct 2011 Location: Van down by the river
| Re: 3 Racig Winch |
02-22-2012, 10:34 AM | #12 |
| Re: 3 Racig Winch |
02-22-2012, 10:52 AM | #13 |
| Re: 3 Racig Winch |
02-22-2012, 11:27 AM | #14 |
| Re: 3 Racig Winch |
02-26-2012, 08:59 AM | #15 |
| Re: 3 Racing Winch
Can the 3 Racing winch pick up a slash 4x4 Why yes it can 3 Racing winch - YouTube |
02-27-2012, 01:32 PM | #16 |
| Re: 3 Racing Winch
just order a Aluminum front bumper mount as you can see in my video The bumper got pulled down. however the mount did not brake i think aluminum would be better |
03-01-2012, 11:35 AM | #17 |
| Re: 3 Racing Winch
The Aluminum mounts should be in today. Will post pics later tonight
3 Racing Winch - Similar Threads | ||||
3 racing winch on 3s | omenwolf | Electronics | 4 | 01-14-2012 05:57 PM |
3 racing winch help | johnnybrcman7 | Electronics | 2 | 10-09-2011 08:29 PM |
3 racing winch | dingo2010 | Electronics | 2 | 04-27-2011 08:39 AM |
racing winch ? | hotrodsonoma | Electronics | 6 | 03-25-2011 04:37 PM |
