03-01-2012, 07:29 AM | #1 |
Newbie Join Date: Feb 2012 Location: vancouver
| help with scx10 dingo
hey guys. i just got a dingo,and it has the ae2 esc,and a axial 27 turn motor wich is to fast for me. what is a good motor that would bolt in thats say 55t or,and maybe waterproof???
03-01-2012, 07:35 AM | #2 |
| Re: help with scx10 dingo
Holmes Hobbies and Brood seem to be the top 2 players in that range. Most of the guys in our club run HH but a few guys are trying out Brood now. Brushed motors are essentially waterproof. With minimal maintenance, a quality motor should run for a long time. Holmes Hobbies makes a great esc for crawling, the BR-XL. It can be ordered waterproof and is 6s capable... |
03-01-2012, 06:51 PM | #3 |
Newbie Join Date: Nov 2011 Location: Simpsonville, SC
I have the Axial 55t motor and it works good for me. At about $12 it works really good. LOL
03-01-2012, 07:04 PM | #4 |
Rock Crawler Join Date: Jan 2010 Location: [loh-key-shuhn]
I wouldn't recommend a 55t motor in a scaler, unless you want to get there next month. If you have the RTR, which it seems you do, you have a 20t pinion on the 27t motor. A more common set-up is a 35t motor and 14t pinion (both of which will slow the Dingo). Motors will vary in price and quality. If you want to run in water get a cheap one, or do regular maintenance on the expensive ones. Water (actually things in the water) wears brushes. Have fun with it. |
03-01-2012, 08:49 PM | #5 |
Pebble Pounder Join Date: May 2011 Location: The Wizzle, MA
| Re: help with scx10 dingo Instead of spending dough on a new motor, try a larger pinion and/or smaller spur gear.
03-01-2012, 08:59 PM | #6 |
Pebble Pounder Join Date: Dec 2005 Location: W. Richland
Holmes Hobbies makes some good motors. 27T-35T seem to work good for trails. 55T Crawls pretty slow. I went 35T for mine and I crawl and run trail. It works great for me. It still has some slow speed control (not as much as you'd get with a 55T), but its also got some wheel speed when you need it. If its a dedicated crawler that doesn't see a whole lot of hills, mud, or anything that will require wheel speed, then you might as well go 55T. If you're going to do both then maybe a 35T would be a good compromise for you. Try and find some body else in your area that has a higher turn motor and see if you can get some time behind the remote. It would probably help you decide what you want to run.
03-02-2012, 07:12 AM | #7 |
| Re: help with scx10 dingo Wouldn't a larger pinion or smaller spur make it faster? turbocivic90 says it's too fast now. I understand the closer the spur and pinion tooth count gets, the faster it goes.
03-02-2012, 07:33 AM | #8 |
Quarry Creeper Join Date: Aug 2011 Location: United Kingdom
Your cheapest option would be to buy a 14T pinion. That will slow it down a bit and give it better crawlability |
03-02-2012, 08:01 AM | #9 |
| Re: help with scx10 dingo |
03-02-2012, 11:27 AM | #10 |
Even though it's a throw away motor the stock 27T isn't a bad motor.. Mine have all been very smooth and last a while if you clean and lube the bushings and don't heat it up too much. You should gear it down.. Start with a smaller pinion.. You can go down to a 12T if need be. |
03-02-2012, 03:28 PM | #11 |
thanks for the info guys,going to put a 14t on and see how it works.
03-05-2012, 12:25 AM | #12 |
Great Let us know if you happy! |
03-05-2012, 08:10 PM | #13 |
works better. probably will drive it with this untill find a setup i like. any input on motor and esc?
03-05-2012, 08:55 PM | #14 |
Quarry Creeper Join Date: Jul 2009 Location: Back from vacation!!!
The AE-2 will serve you fine. I see really no-need to change it IMO, I'm gonna run mine till it smokes, if it ever does. It is programmable via manually or Castle-Link. I flop around on motors. Like the wheelspeed of the stock Axial 27t, but run a HH 35t from time to time too.
03-05-2012, 09:36 PM | #15 |
thanks for your input
help with scx10 dingo - Similar Threads | ||||
scx10 dingo | rockslide710 | Axial SCX-10 | 4 | 02-28-2012 06:38 PM |
SCX10 Dingo | T-BONE35 | Newbie General | 6 | 02-05-2012 05:43 AM |
SCX10 Dingo | Solitaire | Axial SCX-10 | 5 | 12-06-2011 12:30 AM |
SCX10 Dingo wb 11.4 to wb 12.3 | rafiki.engineering | Axial SCX-10 | 4 | 10-20-2010 12:20 PM |
