04-09-2012, 09:24 AM | #1 |
Rock Stacker Join Date: Jan 2012 Location: nc
| 4 link front end scx10
hey guys would my scx10 run better if i 4 linked the front end like the rear is? and if so what kind of kits or homemade ideas are out there? thanks guys |
04-09-2012, 10:27 AM | #2 |
Pebble Pounder Join Date: Feb 2012 Location: Freakville
| Re: 4 link front end scx10
Look up Stainless Steel Links in the Vendor section and you will find quite a few options. If you 4 link the front you will need to relocate the servo, so search for "CMS" Chassis Mounted Servo and you will see a host of options aswell. Goood Luck!! |
04-09-2012, 10:39 AM | #3 |
Rock Crawler Join Date: Apr 2009 Location: Pa
You don't have to move the servo to add a 4-link if you have the right plate. TCS makes a 4-link plate that keeps the servo in the stock position. I used to have the TCS 4-link I just mentioned on mine. I replaced it with a TCS Boomerang (have one on the rear too) and machined up a new bracket to relocate the servo. I did have to clearance the one crossmember and countersink the top of the plate for a flathead screw on both plates though. Not a big deal and works well.
04-09-2012, 07:19 PM | #4 |
i saw the 4 link plate by axial will that work its made 4 the ax10
04-09-2012, 09:06 PM | #5 |
Rock Stacker Join Date: May 2010 Location: Tacoma
I 4 linked the front and rear, using all stock hardware that came with the kit servo still on the axle.
04-09-2012, 09:14 PM | #6 |
| Re: 4 link front end scx10 |
04-09-2012, 09:33 PM | #7 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
My Dingo is 4 linked front and rear using the alum upgrade kit. Used the 4 link bracket that came with the Dingo extra parts and the stock servo mount. Fully compressed, the servo fits right into the cavity ahead of the radio box with all kinds of clearance. The issue must be with longer wheelbased SCX10's |
04-09-2012, 09:38 PM | #8 |
You can 4-link the front using the 4-link truss from the RTR model. You can see how it works by looking at the link kit instructions. http://docs.axialracing.com/instruct...cx10-links.pdf Last edited by k7zpj; 04-09-2012 at 09:40 PM. |
04-10-2012, 02:09 AM | #9 |
Quarry Creeper Join Date: Aug 2011 Location: United Kingdom
Has anyone gone from an Axial aluminium 3 link front to an Axial aluminium 4 link front? By Axial I mean all links and connectors being from the Axial aluminium link kit? If so did you achieve slightly more articulation up front? |
04-10-2012, 05:24 AM | #10 | |
RCC Addict Join Date: Jul 2009 Location: Dover, NH
| Re: 4 link front end scx10 Quote:
You will not gain articulation as it is the shocks that limit that, not the link setup (in the stock Axial config). The 3 link upper allows for way more articulation then the shocks can provide. Your down travel is limited by the shocks overall length. And the up travel is limited by the shock body bottoming out on the shock travel limiter on the shock shaft (if installed). Disconnect the shock from the rig and see how much the axle can travel. Much more then if the shock is installed, so it is not the link setup that is limiting it. What a 4 link can help with is strength (3 link connection at the axle ball joint can pull out of the bracket). Or with performance with correct tuning. Too much to get into here about that. And yes the Axial servo/4 link plate will work on an SCX10. I have it on one of mine. Though you may have to be creative with upper links to get the right pinion angle and caster. I run home made links lower and upper on the rig with the Axial 4link/servo mount so I am not sure if there is a stock link length setup that will measure out correctly. Good luck | |
04-10-2012, 01:18 PM | #11 |
axial told me the same thing the 3 link is fine its the shocks that need to be updated so i guess i will leave the 3 link since i have the alumunim lnk kit coming for the stock conf
12-11-2014, 07:18 PM | #12 | |
Quarry Creeper Join Date: Dec 2014 Location: Tulsa
12-11-2014, 07:53 PM | #13 |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
| Re: 4 link front end scx10 It's really late, but going from 3 link to 4 link also helps with axles movement from side to side. So it can perform the way it was designed to and help steering.
03-26-2015, 06:29 AM | #14 |
Pebble Pounder Join Date: Jan 2015 Location: Calgary
I know this is an old thread, but if i use the 4 link playe from the ax10 will i have to do a cms? Not sure if it makes a diffrence but im running a 2012 jeep wrangler.
03-26-2015, 06:52 AM | #15 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
You have all the parts you need in the spair parts bag that came with your kit. If you bought the axial metal links kit you still have all the extra parts to 3 or 4 link and you will have the parts to set your pinnion angle in the aluminum links stuff. You don't need the extra 4 link plate. But it's your call. You will need the 4 link truss tho it's in the bag and the servo sit right on top of it just as before. This works on the dingo scx10 deadbolt and the ax10 scorpion I have all of them set up that way with the 4 link truss.
4 link front end scx10 - Similar Threads | ||||
5 link front end in full chassis scaler | 1tuff40 | General Scale Talk | 7 | 01-08-2009 06:38 AM |
2 link on front end???? | sabantw200@yaho | General Crawlers | 9 | 06-01-2007 09:23 PM |
