06-09-2012, 02:35 PM | #1 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
| small question.........
anyone know if th mojave body fits the scx10 ? Complete Mojave Body Set for Trail Finder 2 (White) |
06-09-2012, 08:41 PM | #2 |
RCC Addict Join Date: Jul 2009 Location: Dover, NH
| Re: small question.........
it can. There are two SCX10 wheelbases 11.4 and 12.3(?). It is much closer to the original scx10 kit wheelbase or Dingo version. The Honcho is about an inch too long. But that is easily changed. All you will have to do is modify some links or buy or make some new ones. I like the make you own route as you can make them "exactly" what they need to be. I think the TF2 Mojave body is about 11.5 inch wheelbase. I think it is the same as the Tamiya which I just measured. most of the parts interchange. That is why I think it is the same. I run mine at 11.5 as I run a larger 1.9 tire on it and trimmed the front of the front wheel well and lower grill (very common thing to do). With a smaller tire, you could probably run the 11.4 inch wheelbase without tire rub. Either way, it is very easy to run that body on an SCX10 with very common parts. Depending on your model of SCX10 and the tires you want to run, you may be able to just bolt it up and go. Good luck
06-09-2012, 11:57 PM | #3 |
Nice one thanks.
small question......... - Similar Threads | ||||
Newbie Kit Question, small set screws | holiday13 | Axial Wraith | 11 | 05-04-2012 11:33 AM |
Question bout a 350 small block | truegaintfree | Chit Chat | 5 | 06-05-2011 09:30 AM |
Need more "punch" small battery question. | TurboShadow | Electronics | 6 | 04-06-2011 04:15 PM |
Small Engine Question | rcbif | Chit Chat | 5 | 03-22-2007 10:54 PM |
