08-19-2012, 01:40 PM | #1 |
Rock Stacker Join Date: Nov 2010 Location: Dover
| first scx10 build
here are the pics to my First SCX10 build Box Stock |
08-19-2012, 01:43 PM | #2 |
| Re: first scx10 build |
08-19-2012, 01:47 PM | #3 |
Removed Limiters in shock got pleantey more flex and new tires integy type 3 super soft with memory foam inserts |
08-19-2012, 01:48 PM | #4 |
Integy Alum front C hubs and steeering links |
08-19-2012, 01:49 PM | #5 |
Pebble Pounder Join Date: Apr 2012 Location: sa
Tires look great! keep the pics coming!
08-19-2012, 01:50 PM | #6 |
using alum bracket and Servo box raised electronics to keep away from water |
08-19-2012, 01:51 PM | #7 |
Raised bumper |
08-19-2012, 01:53 PM | #8 |
Needed more clearance added Gmade 108mm shocks and RC4WD Mickey thompson 1.9 |
08-19-2012, 01:55 PM | #9 |
Added 3 racing whinch |
08-19-2012, 01:57 PM | #10 |
Just a small amount of cutting to stock bumper plate and perfect fit |
08-19-2012, 02:00 PM | #11 |
Piece of alum wire and small spring cut wire in to and insert spring for a scale CB ant |
08-19-2012, 02:02 PM | #12 |
Scale CB ant installed added few scale items |
08-19-2012, 02:04 PM | #13 |
08-19-2012, 02:05 PM | #14 |
Rock Crawler Join Date: Aug 2011 Location: Baton Rouge
You coming with it on your SCx! Congrats to you and definitely subing to see where you go with this one bro!!!
08-19-2012, 02:08 PM | #15 |
08-19-2012, 02:19 PM | #16 |
wated a easy and cheap way to use my winch off my radio without spending $100. or so surfing the net i found this idealand it worked perfect using a 2ch radio and a 3 pole switch (purchesed from radioshack 2.99 pckg of 2) here is how you do it youll need the 3 pols switch 2x male reciver plugs 1x female reciver plug 1)Rx: reciver wire(white or yellow) to center post 2)Rx (+) wire to other center post 3)Attach all negative wires together (not on any post) 4)Attach all remaining wires to any post (one wire per post) 5) Remove servo plug from reciver insert the rx end of the switch to into the reciver and then put the plug from the winch into one side and the servo plug into remainig side with a simple flip of the switch you can operate your winch with you steering flip back and your back to steering servo ill post pics later thanks |
08-19-2012, 02:40 PM | #17 |
Rock Crawler Join Date: Aug 2011 Location: tri cities
Looks good man. You might want to add some weight to the tires after lifting it that much. It may have a problem side hilling.
08-19-2012, 02:49 PM | #18 |
08-19-2012, 02:51 PM | #19 |
08-19-2012, 03:53 PM | #20 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
it went right along last night pretty good !!! had a ton of fun with everyone in the dark...lol... i'm gonna find a spot out by my place for us to hit up next crawl... that cb antennae was a blast to see..if it were like 1" longer it would probably wobble all over like the one on your cherokee |
first scx10 build - Similar Threads | ||||
The C.O.A.T. SCX10 build | mitchr97 | Axial SCX-10 | 154 | 02-19-2013 03:21 PM |
Pinchflat's SCX10 "WTF am I going to build" Build. | PinchFlat | Axial SCX-10 | 99 | 10-09-2012 12:59 PM |
my scx10 build | bowmansscx10 | Axial SCX-10 | 6 | 04-18-2011 06:24 AM |
my first scx10 build | axialchevy | General Scale Talk | 1 | 03-10-2011 07:15 AM |
