09-02-2012, 03:03 PM | #1 |
Newbie Join Date: May 2012 Location: HAEDO
| problems with my twitch engines scx10
Hi guys, I have a axial scx10 honcho. which has xl-5 esc and traxxas titan 12t. not because when I put it in the water is broken, muddy water, and if I put the water touches the engine begins to stall and lose power until it reaches a point for accelerated and smoke from the coals pushed him to turn the motor truck and grabs. but I break the motor brushes! Titan not only this but also those of axial 20t! I thought it was the esc the change and does the same! help me I'm desperate I can not get into the water to break! sorry if my English is not good to use the google translator thank you very much for reading! |
09-02-2012, 08:12 PM | #2 |
I joined the Band! Join Date: May 2009 Location: Palm Bay
| Re: problems with my twitch engines scx10
I will try to write this so it translates into something you can read clearly. The Titan is a bad motor. The Axial motor is not much better. I would recommend purchasing a different motor of a higher quality. Any electric motor should work under water with no problems. I see you changed the esc to a different one, but the problem remained. I would guess the problem is in the bad motors. They are made of poor quality and usually do not last a long time. A better motor would be one made by a different company like Holmes Hobbies or Tekin. Hope this helps and hope it is readable when you translate it.
09-02-2012, 09:37 PM | #3 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
get a novak motor
09-03-2012, 02:04 PM | #4 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
Orion is rebuildable also.
09-03-2012, 05:31 PM | #5 |
friends which is the fastest engine? that those who were very very fast burn. The last thing I bought was a 55t firwal vennom had no problem but it is very very slow!! I want something fast as the traxxas titan 12t motor that you recommend? and that's a good quality to get him into the water thank you very much. |
09-03-2012, 05:36 PM | #6 |
My friends say that I found these on ebay.? http://www.ebay.com/itm/Team-Orion-M...item53ee821856 http://www.ebay.com/itm/Novak-3520-T...item1e6ef263db http://www.ebay.com/itm/Tamiya-53929...item20cae31208 by desert already underway box 2 speed of traxxas summit "Thumbsup" and another thing where I can get spare coals for these engines repairable? Last edited by mr.imbert; 09-03-2012 at 06:02 PM. |
09-05-2012, 01:15 PM | #7 |
My friends say that I found these on ebay.? http://www.ebay.com/itm/Team-Orion-M...item53ee821856 http://www.ebay.com/itm/Novak-3520-T...item1e6ef263db http://www.ebay.com/itm/Tamiya-53929...item20cae31208 by desert already underway box 2 speed of traxxas summit "Thumbsup" and another thing where I can get spare coals for these engines repairable? |
problems with my twitch engines scx10 - Similar Threads | ||||
scx10 problems???? | dunwoody | Axial SCX-10 | 1 | 05-18-2011 05:44 PM |
Servo twitch makes truck go crazy...news at 10! | day215 | Electronics | 7 | 11-17-2010 09:32 PM |
Servo twitch. | theinjected1 | Losi Micro-Rock Crawler | 4 | 09-09-2010 05:47 PM |
wtf?.... uber twitch of doomb? | carzlutt | Electronics | 4 | 01-19-2009 01:39 PM |
twitch and ditch | bondt | Tamiya TLT Crawlers | 8 | 12-21-2006 05:48 PM |
