10-16-2012, 06:00 PM | #1 |
Quarry Creeper Join Date: Jan 2011 Location: Hurricane
| 4 link front axle
Does anyone make a 4 link that can be used on the front axle along with the servo mount? I need to leave my servo on the axle but I want to do a 4 link front. Thanks for your support.
10-16-2012, 06:16 PM | #2 |
| Re: 4 link front axle STRC CNC Machined Alum. Front or rear adj. 4 link Servo Plate for AX10 (Black) Used these in the past and still have one on my kid's rig. |
10-16-2012, 06:18 PM | #3 |
Pebble Pounder Join Date: May 2011 Location: The Wizzle, MA
The basic Axial 4-link truss works fine on the front. It's plastic, but I've not had any problems with it.
10-16-2012, 06:23 PM | #4 |
Thanks guys.
10-16-2012, 06:32 PM | #5 |
The Axial truss/upper link mount does away with one of the servo plate's mounting bolts. I run as-long-as-possible bolts in the other two mounting posts and it hasn't been an issue. The plastic truss also allows the rod ends to rub on the bottom of the servo plate. I could see wear marks after little use so I drilled a couple holes above the rod end bodies to allow clearance. I also used T-maxx 104mm turnbuckles for upper links. Worked perfect for me, as I stretched the front a couple mm's and clocked the pinion up. The benefit to the AX-10 style 4 link plate is the ability to run the upper links on top of the plate, increasing the axles vertical seperation. The downer is that you have shorter upper links, which create more pinion angle change. |
10-16-2012, 06:40 PM | #6 |
With the ax10 plate, making your own links is necessary to dial in your desired axle clocking. The hpi savage flux turnbuckles work awesome as upper links too, they allow for clocking to be changed on the fly. Then make your links afterwards copying their length.
10-16-2012, 07:40 PM | #7 |
Rock Crawler Join Date: Apr 2009 Location: Pa
The TCS front 4 link mount for the servo will work. You will have to clearance the crossmember and countersink the top holes for flathead screws. At least I had to on my stock height SCX-10.
4 link front axle - Similar Threads | ||||
Narrowing front Wraith Axle for front of scx10 | rusty577 | Axial SCX-10 | 12 | 02-02-2013 10:30 PM |
LNC front axle teardown/axle shaft removal guide? | LowLock | Team Losi Comp Crawler | 1 | 05-22-2011 09:31 PM |
front steering linkage behind front axle kit? | slip408 | Axial AX-10 Scorpion | 8 | 09-14-2008 01:16 AM |
IFS w/ 4 link front and 3 or 4 link rear. | T-Man | Traxxas Crawlers | 6 | 10-26-2004 07:28 AM |
