05-17-2015, 07:55 PM | #1 |
Rock Crawler Join Date: Aug 2011 Location: SB
| My motor and esc choice
Hello, After much research, and what is left in my budget, I came up with this combo. A RC4WD Brushed 35T Boost Rebuildable Crawler Motor, and a SV3 Sidewinder esc, stock spur, and pinion. Is this a good choice for the money are is their something better around the same price? Budget is around $150. I do like the esc as I can now use my field link card motor ? Thanks all |
05-17-2015, 08:01 PM | #2 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
Holmes hobbies 13t and brxl
05-17-2015, 08:10 PM | #3 |
| Re: My motor and esc choice
Can I use my field card with the brxl? I can afford the HH 13t and brxl, but on HH website its looks like you can only use Stick and Castle Link programming compatible? I don't no if that includes the field card. I did email HH with no reply
05-17-2015, 08:46 PM | #4 |
Do I get the Castle Creations Link Quick Connect $12.99, or the Castle Creations Castle Link Programming Kit 21.99 or both for the brlk esc? Damm for this price I sould go brushless How about the Novak Timbuk2 BL System 13.5T: Wraith Edition & 5ABEC? Actually my buddy smoked his after just a month. Maybe save up for the Teken Roc 412 and a MMP. would the Tekin Redline GEN2 Sensored Motor (17.5T) work good for crawling? Last edited by desertdude; 05-17-2015 at 09:17 PM. |
05-17-2015, 09:14 PM | #5 |
You can brushless is use by some. Holmes make some awesome brushless stuff. You need the castle link I got mine on here for 10. If you go brushless it needs to be sensored set up!
05-17-2015, 09:19 PM | #6 |
Sensored so their is no cogging correct
05-17-2015, 09:23 PM | #7 |
You can run a servo off of the brxl. I have read on the forum, some one said up to a 200oz servo. That would save you money but, I would still use a bec.
05-17-2015, 10:37 PM | #8 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
For a very smooth brushed setup - Go HH BRXL and your choice of brushed motor. Brushed motors don't like heat or water. So factor that in. OR A cheap brushed setup - HOBBYWING North America — QUICRUN 16 Brushed ESC And a Traxxas Titan 21t 550 motor. Won't have the super low end as the expensive rebuildable motors, but it's dumb and takes a beating. OR Cheap brushless setup Hobbyking® X-Car 120A Brushless Car ESC (sensored/sensorless) (US Warehouse) Turnigy TrackStar 10.5T Sensored Brushless Motor 3250KV (US Warehouse) My current Setup Castle MMP Turnigy TrackStar 10.5T Sensored Brushless Motor 3250KV (US Warehouse) My SCX10 weighs 5lbs so I don't feel the need for a bigger 4 pole motor. I run 1.9 tires on my SCX10, so I can get away with a Solar D772 servo. I run a BEC pushing 8 volts to my servo. Have done this with no issues for over a year. |
05-17-2015, 10:45 PM | #9 |
| Re: My motor and esc choice |
05-17-2015, 11:06 PM | #10 |
Spent a lot on this G-6 build so I just ordered a Tekin roc 412 3100kv, and a MMP. Im all tapped out this month now man..
06-10-2015, 11:15 AM | #11 | |
| Re: My motor and esc choice Quote:
EDIT: Does the QUICRUN 10 ESC (2-3S) BRUSHED have drag brake? Last edited by Natedog; 06-10-2015 at 06:27 PM. | |
06-10-2015, 08:05 PM | #12 |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
| Re: My motor and esc choice Last edited by DowntownScience; 06-10-2015 at 08:09 PM. |
06-10-2015, 08:07 PM | #13 | |
06-10-2015, 08:11 PM | #14 | |
06-10-2015, 08:21 PM | #15 | |
06-10-2015, 11:16 PM | #16 | ||
| Re: My motor and esc choice Quote: Quote:
Could go with 17.5 turn. | ||
My motor and esc choice - Similar Threads | ||||
Motor and ESC choice | dan.loeb | 1.9 Scale Rigs | 2 | 02-23-2013 11:21 PM |
ESC choice | hibbs | Electronics | 2 | 01-27-2012 03:45 PM |
Choice for ESC or ESC motor combo | fivepointnine98 | Newbie General | 10 | 07-05-2011 03:21 PM |
ESC and Motor Choice | LostCrawler | 1.9 Scale Rigs | 0 | 04-15-2011 09:53 AM |
Noob needs help in motor and ESC choice... | TheWiking | Electronics | 10 | 03-25-2007 05:00 PM |
