Thread: My motor and esc choice
Old 05-17-2015, 07:55 PM   #1
Default My motor and esc choice
Hello,
After much research, and what is left in my budget, I came up with this combo. A RC4WD Brushed 35T Boost Rebuildable Crawler Motor, and a SV3 Sidewinder esc, stock spur, and pinion. Is this a good choice for the money are is their something better around the same price?
Budget is around $150. I do like the esc as I can now use my field link card motor ?
Thanks all
desertdude is offline   Reply With Quote
Old 05-17-2015, 08:01 PM   #2
snapon boy's Avatar
Holmes hobbies 13t and brxl
snapon boy is offline   Reply With Quote
Old 05-17-2015, 08:10 PM   #3
Default Re: My motor and esc choice
Can I use my field card with the brxl? I can afford the HH 13t and brxl, but on HH website its looks like you can only use Stick and Castle Link programming compatible? I don't no if that includes the field card. I did email HH with no reply
Old 05-17-2015, 08:46 PM   #4
Do I get the Castle Creations Link Quick Connect $12.99, or the Castle Creations Castle Link Programming Kit 21.99 or both for the brlk esc?
Damm for this price I sould go brushless How about the Novak Timbuk2 BL System 13.5T: Wraith Edition & 5ABEC? Actually my buddy smoked his after just a month. Maybe save up for the Teken Roc 412 and a MMP. would the Tekin Redline GEN2 Sensored Motor (17.5T) work good for crawling?
Old 05-17-2015, 09:14 PM   #5
snapon boy's Avatar
You can brushless is use by some. Holmes make some awesome brushless stuff. You need the castle link I got mine on here for 10. If you go brushless it needs to be sensored set up!
Old 05-17-2015, 09:19 PM   #6
Sensored so their is no cogging correct
Old 05-17-2015, 09:23 PM   #7
snapon boy's Avatar
You can run a servo off of the brxl. I have read on the forum, some one said up to a 200oz servo. That would save you money but, I would still use a bec.
Old 05-17-2015, 10:37 PM   #8
For a very smooth brushed setup - Go HH BRXL and your choice of brushed motor.
Brushed motors don't like heat or water. So factor that in.
OR
A cheap brushed setup -
HOBBYWING North America — QUICRUN 16 Brushed ESC
And a Traxxas Titan 21t 550 motor.
Won't have the super low end as the expensive rebuildable motors, but it's dumb and takes a beating.
OR
Cheap brushless setup
Hobbyking® X-Car 120A Brushless Car ESC (sensored/sensorless) (US Warehouse)
Turnigy TrackStar 10.5T Sensored Brushless Motor 3250KV (US Warehouse)
My current Setup
Castle MMP
My SCX10 weighs 5lbs so I don't feel the need for a bigger 4 pole motor.
I run 1.9 tires on my SCX10, so I can get away with a Solar D772 servo.
I run a BEC pushing 8 volts to my servo. Have done this with no issues for over a year.
robertjpjr is offline   Reply With Quote
Old 05-17-2015, 10:45 PM   #9
MODERATOR™
EeePee's Avatar
Originally Posted by snapon boy View Post
I red on the forum some one said up to a 200oz servo. Is that would save you money
Spell check on aisle one.
I ran a HiTec 7950 and 5645 off a BRXL no sweat.
EeePee is offline   Reply With Quote
Old 05-17-2015, 11:06 PM   #10
Spent a lot on this G-6 build so I just ordered a Tekin roc 412 3100kv, and a MMP. Im all tapped out this month now man..
Old 06-10-2015, 11:15 AM   #11
Natedog's Avatar
OR
OR
My current Setup
Castle MMP
Very nice, I might try that Hobbyking sensored setup. I've been gearing down more lately for better slow crawling, but am losing more wheelspeed than I want. I'm currently at 11/56 gearing with Traxxas 21T Titan.
EDIT: Does the QUICRUN 10 ESC (2-3S) BRUSHED have drag brake?
Old 06-10-2015, 08:05 PM   #12
Can't you get a tekin fxr combo for $150?
http://pages.ebay.com/link/?nav=item...243565&alt=web
DowntownScience is offline   Reply With Quote
Old 06-10-2015, 08:07 PM   #13
OR
OR
My current Setup
Castle MMP
I think you mean brushless don't like water. You can run a brushed inside a cup of water!
Old 06-10-2015, 08:11 PM   #14
All of my hobbywing esc's have drag brake. However the manual for that esc shows nothing about how to set anything but throttle mode which is with a jumper. Not so sure on that one but leaning toward no.
Old 06-10-2015, 08:21 PM   #15
My current Setup
Castle MMP
[url=http://www.hobbyking.com/hobbyking/store/__41187__Turnigy_TrackStar_10_5T_Sensored_Brushles s_Motor_3250KV_US_Warehouse_.html
Turnigy TrackStar 10.5T Sensored Brushless Motor 3250KV (US Warehouse)[/url]
That is ALOT of motor for crawling! How hot does your ESC get?
Old 06-10-2015, 11:16 PM   #16
Natedog's Avatar
Hobby wing set up is less.
Corrosion X or conformal coating can fix that.
Could go with 17.5 turn.
My motor and esc choice - Similar Threads
Motor and ESC choice dan.loeb 1.9 Scale Rigs 2 02-23-2013 11:21 PM
ESC choice hibbs Electronics 2 01-27-2012 03:45 PM
Choice for ESC or ESC motor combo fivepointnine98 Newbie General 10 07-05-2011 03:21 PM
ESC and Motor Choice LostCrawler 1.9 Scale Rigs 0 04-15-2011 09:53 AM
Noob needs help in motor and ESC choice... TheWiking Electronics 10 03-25-2007 05:00 PM
