01-04-2013, 07:47 AM | #1 |
Newbie Join Date: Jan 2013 Location: Costa Rica
| SCX10 JK Rubicon - Bent Axle Shaft and Lower Link
I just bought a SCX10 Wrangler Rubicon, and while doing wheelies in my back yard, some things bent... I have some questions to the Honcho and Axial knowledge ppl out there: 1. Could the bent drive shaft be a by product of the slightly bent lower support link? 2. Should I replace the bent shaft with the provided spare plastic part, or should I be ordering a beefier one? (If new shaft is in order, please let me know which one is a good bulletproof option) 3. As or the link: Should I just order the Axial alumi links, or are there other better options? I always break stuff in my 1:1 Jeep, but I was not planing to brake stuff so soon in the 1:10... o well, part o the hobby... |
01-04-2013, 07:58 AM | #2 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
| Re: SCX10 JK Rubicon - Bent Axle Shaft and Lower Link
That twisting is not from the links being bent, but rather that the drive shafts are plastic. Most guys upgrade to the MIP drive shafts, Junfac or RC4WD metal shafts. As for links, here is another option...... http://www.rccrawler.com/forum/chass...-scx-10-a.html Also, available in 1/4" stainless, as well as upper links and steering kits. Last edited by R2j; 01-04-2013 at 08:14 AM. |
01-04-2013, 08:05 AM | #3 |
It's the drive shafts... The shaft is hollow and allows it to collapse a little and then twist itself into a twizzler. You could replace it with another stock part but this time put something in the hollow center like a wood dowel or a piece of threaded rod.. Something to make the shaft solid.. It'll last a lot longer that way. Or if you want to spend money you could go ahead and look at stronger aftermarket replacements.. MIP is the standard for strength and is what I upgrade to when it's time. Be prepared to spend about $60 though. |
01-04-2013, 08:31 AM | #4 |
Pebble Pounder Join Date: Jul 2007 Location: Oveido, Florida
install new parts and stop doing wheelies
01-04-2013, 08:38 AM | #5 |
Rock Crawler Join Date: Dec 2011 Location: Virginia
you need some MIP shafts. they are pricey but fit a large variety of vehicles so you can recycle them. last shafts you will ever buy |
01-04-2013, 08:45 AM | #6 | |
Rock Crawler Join Date: Oct 2009 Location: 6512 Elevation
| Re: SCX10 JK Rubicon - Bent Axle Shaft and Lower Link Quote:
01-04-2013, 09:02 AM | #7 |
Quarry Creeper Join Date: Jul 2012 Location: Alpharetta, GA
I'm partial to R2J's stuff so I vote there for links. His stuff has held up well on my Wraith. I'm also with the others saying that if you make the male portion of the driveshaft solid it will last much longer. I used M6x65mm bolts from Lowes on my Wraith and they held up for quite a while. I only swapped to MIP's when I went brushless. Cheap Stock drive shaft upgrade |
01-04-2013, 09:44 AM | #8 |
Rock Stacker Join Date: Dec 2012 Location: Fremont
Costa Rica?- Pura Vida! Wow I have a new rtr Rubicon also, wow how do you do wheelies? I see the marks on you battery looks like it is a 2S Gen Ace prob 50C ? Were you using that battery for whellies? or a 3S? also- I'm ording MIP's after reading this. |
01-04-2013, 09:45 AM | #9 |
Wow, great and QUICK info. I´ll go with the reinforced driveshaft for now, and order some MIP new ones for later.... As far as links go, I sent a PM to R2j to order some of his links... "stop doing wheelies".... aggrrr, it´s hard to control the stupid pedal, err, finger Thanks guys Last edited by AgustinCJ7; 01-04-2013 at 10:00 AM. |
01-04-2013, 11:01 AM | #10 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
Yup, stop doing wheelies. Plain & simple. As for the stock plastic links, I like them a lot. Others will tell you they are worthless, but they do their job perfectly. Which is to bend & not break. Once you upgrade your links to AL, SS, or Ti, you WILL start to break knuckles & C-hubs. Now you will need to upgrade those. All of which is not a problem if that's what you want to do, but I like wheeling my stock RTR & making others with all the mods look silly. |
01-04-2013, 02:00 PM | #11 |
No wheelies, got it. I was re-assembling the drive shaft with the spare parts, and noticed that the CV joint is moving freely in on of its axis (the one that rotates in the pin that goes in the drive shaft side), but it is hard to rotate in the axis that is in the axle side. This is creating a vibration. I suspect that this could have been the cause of the bent shaft, as it is not turning freely. Does this make sense? I want to be able to use the Jeep on the weekend, but I don't want to damage the pinion box. New shaft will not be here until 10 or so days... |
01-04-2013, 03:26 PM | #12 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
it's a trail truck, not a wheelie king.
01-05-2013, 11:32 PM | #13 |
So I was able to fix the bent shaft for today´s trail ride with a couple of friends... We had a good time, however, my JK presented a new problem: The front upper suspension link broke free. I can see that the screw is still in the suspension link, but the diff is hanging from the shocks. Is this something common? Having broken parts in 2 out of 3 rides make me wonder on the build quality of this cars, or maybe I´ve got a lemon... My friend with the Dingo has been running his RC for more than a year, with out any trouble, and today, the 2 JK´s had bent rear links, and mine broke the front diff loose (No wheelies or hard stuff). Advice welcomed. |
02-20-2013, 09:08 AM | #14 |
As per the received advice, I bought a set of MIP drive shafts. When trying to install them, I'm having problems with the shaft hitting the pinion housing and protector. (the MIP drive shaft is is bigger and wider than the original, and the clearance is very small). Any advice on what to do to make it fit? Any one else had the same problem? |
02-20-2013, 09:28 AM | #15 |
Quarry Creeper Join Date: Feb 2011 Location: The underground
Just dremel the cover lightly until it fits
02-20-2013, 09:43 AM | #16 |
Newbie Join Date: Feb 2013 Location: Montreal, Quebec, Canada
out of curiosity, what kind of motor are you using ?
02-20-2013, 10:49 AM | #17 |
Using stock Axial 27T motor Used the dremel to remove as much material from the cover as possible, however, the fit is pretty tight there... Stock Drive Shaft MIP Whitout cover MIP With cover |
02-26-2013, 09:17 PM | #18 |
Pebble Pounder Join Date: Aug 2012 Location: Gadrock, Al
I would just remove the cover, i never ran a dust cover on my wraith
SCX10 JK Rubicon - Bent Axle Shaft and Lower Link - Similar Threads | ||||
Axial bent lower link fitment | heefageLA | Redcat Crawlers | 4 | 02-14-2012 05:00 AM |
Advice on bent lower link fitment on RS10 | heefageLA | General Crawlers | 1 | 02-13-2012 11:10 AM |
Bent plastic lower link | Big Daddy | Axial SCX-10 | 9 | 06-29-2011 05:25 PM |
Hot Racing straight axle kit, bent axle shaft | sierradmax | Axial AX-10 Scorpion | 6 | 09-07-2008 01:04 PM |
