02-03-2013, 06:56 PM | #21 | ||
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
| Re: Sluggo's Dingo Build Quote:
An hour sounds about right. I'm not sure why they encouraged you to run a 6-cell NiMH pack, especially on a 3s capable brushless setup. Aside from the weight savings for a given capacity, LiPo has a higher discharge rate to power the more demanding brushless setups. NiMH probably does fine on a brushless crawler, but I'd have gone LiPo all the way. My 3s packs weigh 1/4 of a comparable 6 cell NiMH pack and supply much higher and more stable voltage under load. A win-win for sure. Sorry for the segue Sluggo. Good luck with the electro research. It pays off. | ||
02-03-2013, 07:08 PM | #22 |
Newbie Join Date: Nov 2012 Location: Indianapolis
After running lipo, I'll never go back to nimh.... I would assume that crawlers would benefit just as much as my racers from running lipos. Sent from my iPhone using Tapatalk |
02-03-2013, 07:30 PM | #23 |
Tapstalk didn't update - so posted before the last posts... Thanks again for the info guys...keep it coming! Can styrene sheets be sourced from Hobby Lobby or Michaels? Sent from my iPhone using Tapatalk |
02-03-2013, 07:39 PM | #24 |
A quick search on their websites didn't turn up anything. I searched for both "styrene" and "Plastruct", a common brand of styrene products. I know HobbyTown carries Plastruct styrene products. I made some front fender liners out of .040"(or 1mm) thick styrene sheet.
02-03-2013, 07:41 PM | #25 |
Oh thanks. I'll give HT a look, just not one very close to home. Might just look online. Sent from my iPhone using Tapatalk |
02-03-2013, 07:51 PM | #26 |
Bummer, yea just order it online, along with your motor and ESC. |
Sluggo's Dingo Build - Similar Threads | ||||
Another Dingo Build | bryco13 | Axial SCX-10 | 15 | 06-19-2013 07:08 PM |
Need help with my Dingo build | driftin2crawlin | Axial SCX-10 | 5 | 04-06-2013 08:10 AM |
Ttc dingo build | Chodey24 | 2.2 Scale Rigs | 0 | 08-31-2012 01:29 AM |
My Dingo build sort of. | BillH | Axial SCX-10 | 9 | 02-06-2012 06:46 PM |
Dingo Build up. | mwscooters | Axial SCX-10 | 27 | 10-12-2011 03:27 PM |
