Thread: ESC / electrical box lift?
Old 01-22-2013, 04:58 AM   #1
igz
Question ESC / electrical box lift?
Hi all
I installed 2 more links up front so now I have 4, but when it compresses all the way it's hitting the ESC / electrical control box. Does anyone have any ideas as to how to lift the box by a 1 cm or so?
If you know who did this pls refer me to it.
Many thanx
igz
igz is offline   Reply With Quote
Old 01-22-2013, 07:26 AM   #2
Default Re: ESC / electrical box lift?
You could try some spacers in the parts bag to raise it.
diesel kawboy is offline   Reply With Quote
Old 01-22-2013, 10:21 AM   #3
Proverbial threadkiller
Trubble's Avatar
Mine hit on something when I did that, too, but I can't remember if it was hitting the actual box, or the angled brackets that hold up the box.
No matter, I won a JEVNE RACING battery tray in a giveaway on here (it's good to be a star holder), and used that. Although iirc, then the drive shaft still hit the tray, so I just found some spacers and raised up the back of the tray.
Trubble is offline   Reply With Quote
Old 01-22-2013, 10:42 AM   #4
Move the box to the back and move the heavier battery to the front. Then you will clear everything and you will improve your rig's climbing ability.
BadRockNoCookie is offline   Reply With Quote
ESC / electrical box lift? - Similar Threads
Box for rx and esc Superbeast Axial SCX-10 16 09-22-2012 06:44 PM
electrical contact cleaner on ESC RMack Electronics 5 04-15-2012 06:42 PM
High Lift Steering Box - spline size? sweli General Scale Talk 6 02-25-2012 07:28 PM
Good or Bad to mount ESC inside electrical box.? toyotaexo88 Electronics 7 06-08-2011 01:35 PM
Keeping electrical clean & dry - fishing tackle box ? 4RnrRick Electronics 5 01-08-2005 11:57 PM
