01-20-2013, 01:16 PM | #1 |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
| DRV KRAWLER from Comp to Scaler Almost
I broke down both of my Frogger builds. The "OG" was a great rig. Sold off that rig altogether but, a few small parts remained in the box. Then I broke down the "PD" to build a Scaler for my Son Nicholas. He is 4 and just is not into the Crawler Speeds. He was more interested into a "Basher". Traded off my "PD" Chassis to a member on RCC. for a SCX10 chassis with aluminum links. All of the remaining Parts from the "PD" is going onto this Rig. Any interest in axles, Trans and Electronics can be found here : "The official Tuolumne County Poison Dart" Here we go : Here is the pile of parts thrown into a box after disassembly of the "PD". I was sad to see the Rig torn down it was a KICKA$$ set up. A few items as I got ready to apply what I have learned from the Comp side. I have chosen to follow the Comp type set up and applied to a SCX10 format. Let see what comes of it. This was the first go around with links. Ended up shorter on the wheel base in later photos. I started out with the three link design just to see where it was going. This was my first set up on a SCX10. Except when I built my Foff. Totally different direction than this build. If any interest in what a Foff is : DRV KRAWLER FOFF'en Formula Offroad {UPDATES to come to the this build also}. I modified the front VP 4-link battery servo mount to use on the rear end and used the Rear VP 4-link on the front of this build. |
01-20-2013, 04:41 PM | #2 |
| Re: DRV KRAWLER from Comp to Scaler Almost
Well up and running Pretty Damn quick with the 16t Cralwmaster for HH. My son wanted a Body ASAP. This is all I had and he loves it. I have a second body rough cut waiting to paint. Pretty Funny Looking with a XR body on a SCX10 Chassis. Better protected during the shake down of the running gear. Especially with a $ year old at the Wheel. I did however strip the Kimbrough Spur gear almost instantly. Last edited by DRV KRAWLER; 01-20-2013 at 04:45 PM. Reason: added additional comment. |
01-20-2013, 08:22 PM | #3 |
A few other changes as this has taken place. Here is a few with the body roughly cut. |
01-20-2013, 10:15 PM | #4 | |
| Re: DRV KRAWLER from Comp to Scaler Almost Quote:
Kid's truck is looking pretty good so far. Now you said you were going all stars and stripes on that pickup body, right? (j/k) | |
01-21-2013, 07:08 AM | #5 | |
01-21-2013, 07:24 AM | #6 |
How about a quick run down on parts : Beef tubes front and rear axles O/D Front Axle U/D Rear Axle Front Axial C-Hubs Front Zero Acherman VP Knuckles 3 Racing CVD w/ Gunnar pins Front axle VP Rear lock outs Gunnar Hex pins all 4 corners VP Front / Rear 4-Link paltes reversed and moded front to rear. VP Razors in back (2) 3.5 Traxxas BigBores w/ Mini T Spring cups in the Front (2) 4.0 Traxxas BigBores w/ Mini T Spring cups on the Rear Axial Trans all Robinsion racing intrernals w/ VP Dig Hitech Mg225 for the Dig MIP Drive shafts front and rear HH 16T CrawlMaster Tekin FXR ESC Airtronics 94780 w/ CC Bec VP DH (2) for the front VP SLW V4 w. C.I. Wideners (2) for the rear RC4WD Mud slingers Last edited by DRV KRAWLER; 01-21-2013 at 09:02 AM. Reason: Added info |
01-22-2013, 07:37 AM | #7 |
Well I have only received one comment on this thread SHOCKER. I must say for my first SCX10 built Rig this thing is one of my over all favorite builds. It has been purpose built for my 4 year old Son. He prefers the quicker speeds than the real Crawlers. I really like the effect of the VP Dig unit installed this way. It provides a rear wheel drive for spinning the tires and little roosters. While still being able to lock in the 4 wheel drive for good old "Bashing". One other cool feature is locking the front axle and doing "Brake stands". I will be double checking what pinion gear I am running at present on the 16t HH CrawlMaster. I may go larger for additional speed. I do have the Tekin FXR that can be tuned in addition. I did install the VP Razors on the rear of this Rig. I had them left over from the "PD". With the additional shock height and the Razors have given the rig a "Rake" to it. It seems with the 3.5 Big Bores on the front and the 4.0 Big Bores and Razors on the rear. That it is a formidable climber in must rough terrain. Any thoughts or comments would be appreciated here. I would like to here some opinions on the Suspension set up for sure. |
01-22-2013, 08:25 AM | #8 |
Quarry Creeper Join Date: Nov 2010 Location: Sarasota, Florida
Nice build, looks really good, like all the fancy VP doohickeys on the transmission.
01-22-2013, 08:59 AM | #9 | |||
Must be the significantly longer wheelbase you're running, because on my super short CUCV, I went with Slash front shocks all around (w/ no Razors), and I still wonder if that's too high. But if your little guy likes it, and can wheel it around without it falling over too much, then I'd say however you run it is right enough. Quote:
Having the ability to pop into 2WD should provide some fun with doughnuts (brodies, twisties, spinnies, whatever they're called where you are) and other throttle assisted turning activities. Looks like you've got a pretty solidly built machine there, have fun runnin' it. | |||
01-22-2013, 10:32 AM | #10 | |
Thank you my Friend ! If it was not for you Trading up I would still be building up funds for the Chassis. I hope all is going well on the "PD" set up for you. I have been keeping a eye out for a Thread. Actually with the set up as it is. This rig climbs very well also cresting and down hill is quite capable. I thought at first it was going to be top heavy. I tried really hard too create a 55 to 45 weight split on this build. Without scales not sure but pretty damn close. The over drive front axle with the under drive rear is a huge benefit all together on this rig. | |
01-22-2013, 10:35 AM | #11 |
| Re: DRV KRAWLER from Comp to Scaler Almost |
01-26-2013, 09:35 AM | #12 |
| Re: DRV KRAWLER from Comp to Scaler Almost *COOL UPDATE*
All not good reviews so far on this thread. I am hoping that this addition will make up for it. With running the VP Dig limited space was issue the new battery 11.1 40c 2200. After looking into the situation of mounting it low as possible up front. I grabbed the tool box with all of my misc. Axial plastic left overs. The key parts is from stock Wraith Chassis shock mount. 1 - 20 mm Aluminum link. 4 - Plastic stock servo mounts. 2- Steering link ends. 4 - 5mm Aluminum spacers. 2 - 45 mm Aluminum links. And a few screws and washers. All of the above parts I had Just in the bottom of my tool box. I apologize for the picture Quality. Had to use the Old Camera. If some are interested in better pictures let me know. I have thought about doing a thread on just this mount. it is perfect on clearance and cost. I would be willing to disassemble and do a step by step if anyone is interested. This is the result : |
03-22-2013, 06:59 AM | #13 |
Received these in the mail Yesterday. AWESOME GIVEAWAY by Die-Laughing. GripFab "Grip-Lok" Locker Giveaway #2 I can't wait to install these.
03-22-2013, 10:17 AM | #14 |
I was wondering what was going on over in this camp....... You won again?!?!?!?!? You've been on a giveaway winning tear lately haven't you? Congratulations, lucky bugger! Any progress on that pickup body? And has junior gotten any stick time on it? How's he likiln' it? |
03-22-2013, 04:09 PM | #15 |
I know, can you believe it. I have won quite a bit of Swag this year. THANK YOU Vendors ! No progress on the Body. Been playing with my 1968 Mustang Convertible. Actually very pleased with the over all Running of this rig. I really have no need to change anything other than these Awesome lockers. Nicholas is becoming quite a driver. He prefers the performance of this way more than the Crawler. With the Dig and the 16 t HH motor It is a pretty zippy Rig. The under and over driven axles are really vital in this type of rig in my opinion.
10-16-2013, 07:46 AM | #16 |
updated pictures : |
