02-11-2013, 02:45 PM | #1 |
Quarry Creeper Join Date: May 2010 Location: scotland
| my scx10 (started as a ax10)
bought this as a ax10 and then changed the chassis to a scx10 one i got cheap and robbed all the parts i wanted of the ax10 i havent really done much else apart from adding a set of 1.9`s with flat irons i do have a set of 2.2`s with rock grabbers aswell so i can chop and choose what i need to run with that day i do have two body`s one dodge durango for the 1.9`s and a body that gets called the chinese honcho but it does the job honcho body durango i do have another body but that would mean running a 13.5 inch wb but i dont thnik all use it again and no i did`nt paint it this was with the ax10 chassis and one other mod i done today a four link for the rear using spare parts |
02-11-2013, 03:19 PM | #2 |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
| Re: my scx10 (started as a ax10)
I think the Durango body would look better if you cut the bumpers off and trimmed the rocker panels up to match. The chassis has bumpers... IMO, it looks goofy with both the chassis bumpers (which look good) and the body bumpers (which look goofy). Opinions are like.... well, lets just say everyone has one. Have fun on your build. Looks like you're off to a good start.
06-09-2013, 06:14 PM | #3 |
Rock Stacker Join Date: May 2013 Location: Ramsy, Mn
What is the wheel base on the durango body? Will it fit the honcho?
10-29-2013, 04:03 PM | #4 | |
| Re: my scx10 (started as a ax10) Quote:
its been modded abit since i last posted here and now it has a new honcho body painted copper backed with silver and a new light kit i also fitted a winch not that long ago but i havent had to use it yet as i was waiting for the new body to get here before i fitted it | |
10-29-2013, 08:00 PM | #5 |
Pebble Pounder Join Date: Aug 2013 Location: Wenatchee
Sweet rig. I like that color. I have been wanting a winch but have been on the fence about it for awhile.
10-29-2013, 11:22 PM | #6 |
Pebble Pounder Join Date: May 2008 Location: In Hendertucky
Im in a slow process of doing the same conversion. Converting my AX10 into a scaler, i just need a scx chassis
10-30-2013, 05:45 AM | #7 |
| Re: my scx10 (started as a ax10) |
10-30-2013, 02:09 PM | #8 |
i got one of the topcad alloy gearbox`s today for my scx10 yes they look good but there is a few problems ive found. the bearing`s for the top don`t fit there too big luckily i had new bearing in my old g-box motor mount spacers are two short and one looks like someone has tried cutting it with a blunt saw blade so its not the right length and its abit buggered at on end theres no screw`s to hold it onto your trans case luckily i had some the right length again heres some pics on my truck i forgot to take them before fitting chewed up spacer |
my scx10 (started as a ax10) - Similar Threads | ||||
AX10 vs SCX10 | Mr.JayDeeM | General Crawlers | 8 | 10-28-2011 08:20 PM |
Finally started building my SCX10 and a few questions... | riz | Axial SCX-10 | 15 | 12-28-2009 08:17 PM |
Scx10 or Ax10 | suprazx | Axial AX-10 Scorpion | 7 | 12-30-2008 06:22 AM |
started with ax10 + lots of money = | ol dirty dirt | Axial AX-10 Scorpion | 9 | 10-23-2008 06:53 PM |
