02-11-2013, 04:53 PM | #1 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
| is this a good battery/charger choice for my scx-10 HobbyKing HKC6 charger/balancer turnigy nano-tech 5300mah 30c 2sp2 it is bone stock just out of the box any info would help |
02-11-2013, 05:16 PM | #2 |
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
| Re: is this a good battery/charger choice for my scx-10
I would consider something with a little more power. With a 5A max charge current that charger will be busting it's hump without even being able to charge that battery pack at 1C. Also, if you get a charger that only accepts DC power, be sure you have a power supply with enough wattage and a ~12V output.
02-11-2013, 07:56 PM | #3 |
ya this is the power supply i got for it Input: 100v-240v ~ 50/60hz 1.5A Output: 15v / 4A |
02-11-2013, 09:33 PM | #4 |
I charge all my packs at 1C and use a similar charger (Turnigy Accucell 6) for small packs from 2s 360mAh to 3s 2200mAh and it works great for that, but even though it can handle a 5A charge rate, it already runs pretty warm on a 2.2A charge rate. You will be pushing those components (charger+power supply) pretty hard to get a respectable charge rate for those 5300mAh packs, but I suppose it would work. I personally wouldnt use that setup for anything much more than a 3A charge rate. I would suggest a charger capable of 10A+ charge rate, and a power supply that can provide 1.5-2 times that of the chargers max charge rate. Last edited by 05Fronty4x; 02-11-2013 at 09:41 PM. |
02-12-2013, 10:01 AM | #5 |
Newbie Join Date: Jan 2012 Location: Clarks Summit
I use a Thunder AC6 to charge my packs. Takes a little while to charge higher capacity batteries, but it gets the job done and was only $45. I have heard good things about those turnigy nano-tech batterise, tho. I've been thinking about picking one up myself
02-13-2013, 06:38 PM | #6 |
well got my battery shipped today hopefully it does not take a week to get here
02-24-2013, 03:23 PM | #7 |
charged my truck up and took it out today on the new lipo (5300mha 2s 30c) and it performed flawlessly ran for an hour straight the esc and motor got a little warm in my opinion but u could still touch them with no problem. got back home plugged in to charger to put it in storage mode and my charger said that both cells where at 3.86 volts i am very pleased with this combo
is this a good battery/charger choice for my scx-10 - Similar Threads | ||||
Best battery and charger setup for new SCX 10? | laurensparsons | Axial SCX-10 | 23 | 08-26-2013 04:53 PM |
Going to get the scx 10, need battery/charger advice | Zachary | Electronics | 17 | 05-14-2012 11:54 PM |
Battery and charger choice for a newbie | masexto | Electronics | 2 | 03-23-2012 05:14 PM |
Is this a good battery/charger? | ThumperK15 | Axial Wraith | 9 | 12-16-2011 01:19 PM |
Good Battery and Charger? | Bryan732 | Newbie General | 4 | 07-26-2010 05:41 PM |
