02-23-2013, 08:43 AM | #1 |
Rock Stacker Join Date: Jan 2013 Location: Boise, ID
| Spur and Pinion Gear For Crawling?
I see that CKRC has spur and pinion sets for crawling (60/9), and speed (54/14). My dingo crawls pretty well, but I do have a 18.5T motor and slightly taller tires, so I was looking to get a different spur and pinion set for slower crawling, and maybe a set for speed to run every once in a while. What do you guys think of these ratios? Is there a better place to get the parts?
02-23-2013, 12:10 PM | #2 |
| Re: Spur and Pinion Gear For Crawling?
I have 56/12 right now and it's perfect for both speed and crawling. You don't want to over or under gear a brushless motor, it will cause heat issues. You want your spur/pinion ratio between 4:1-5:1. Just buy a few pinions and play with it. When you find the combo that makes run the coolest, stick with it.
02-23-2013, 05:21 PM | #3 |
I see that the name of the shop that I referenced has been changed to ****. Whats the deal with that? Do you know what the stock spur/pinion is? Where is a good place to order the pinions? Thanks for the help. |
Spur and Pinion Gear For Crawling? - Similar Threads | ||||
Which pinion gear works best with RC4WD Steel spur gear? | e32lover | HPI Wheely King | 8 | 03-10-2013 06:09 PM |
Which spur gear and pinion gear with 35t motor | vegas1973 | General Crawlers | 1 | 08-19-2012 11:42 AM |
Pinion and spur gear help | Josh_Br | Axial AX-10 Scorpion | 6 | 03-02-2012 06:30 AM |
Pinion and Spur gear help please!!! | branster36 | Losi Mini-Rock Crawler | 0 | 03-11-2009 10:20 PM |
spur gear pinion ? | wkxtreme | Newbie General | 4 | 06-28-2008 10:04 PM |
