Thread: problem with new dingo
Old 03-03-2013, 03:04 PM   #1
Default problem with new dingo
picked up a new dingo on ebay not opened but heres the problem the trany and axles spin fine with one finger but as soon as i put on the drive-shafts it feels like its binding up a bit and the truck bounces
any suggestions???
Ohioskills is offline   Reply With Quote
Old 03-03-2013, 03:12 PM   #2
Default Re: problem with new dingo
clock the axles a bit, that should free it up.
crawlhog is offline   Reply With Quote
Old 03-03-2013, 04:21 PM   #3
Be sure and align the set screws that attatch each end of the shafts as well.
05Fronty4x is offline   Reply With Quote
Old 03-03-2013, 09:28 PM   #4
There is a mark on each end of the drive shaft that needs to line up to make sure the drive line joints are lined up correctly or as stated above make sure the set screws are aligned.
k7zpj is offline   Reply With Quote
Old 03-04-2013, 05:31 AM   #5
did that and still correct word is (chattering)
Old 03-04-2013, 06:16 AM   #6
Which drive shaft is having the problem (front or back)? Try testing with only one drive shaft to find the problem one.
Check that your upper links match the type of link and length that are shown in the instruction book.
Old 03-04-2013, 04:31 PM   #7
front and rear but the crazy thing is, is the axles and trany spins freely but as soon as the drive-shafts are on it chatters i clocked the axles and made sure about the drive-shafts but still chatters
problem with new dingo - Similar Threads
Problem with Tekin RS system in my LCC, will a BEC fix my problem? rcboy514 Electronics 3 01-12-2012 05:55 PM
Little bit of a problem, Possibly big problem... C_Money Electronics 11 03-08-2010 05:49 PM
Charger problem or power problem? Rockfrog Electronics 4 10-09-2009 01:10 PM
